U6217 原边内置MOS 18W电源芯片,U6773 原边内置MOS 15W电源芯片
U6217S is a family of a high performance Primary Side Regulation (PSR) power switch with high precision CV/CC control ideal for charger applications. In CV mode, U6217S adopts Multi Mode Control which uses the hybrid of AM (Amplitude Modulation) mode and (Frequency Modulation) FM mode to improve system efficiency and reliability. In CC mode, the IC uses PFM control with line and load CC compensation. The IC can achieve audio noise free operation and optimized dynamic response. The built-in Cable Drop Compensation (CDC) function can provide excellent CV performance. U6217S integrates functions and protections of Under Voltage Lockout (UVLO), VDD over Voltage Protection (VDD OVP), Cycle-by-cycle Current Limiting (OCP), Short Load Protection (SLP), and VDD Clamping. U6217S is available in SOP8
U6773S is a family of a high performance Primary Side Regulation (PSR) power switch with high precision CV/CC control ideal for charger applications. In CV mode, U6773S adopts Multi Mode Control which uses the hybrid of AM (Amplitude Modulation) mode and (Frequency Modulation) FM mode to improve system efficiency and reliability. In CC mode, the IC uses PFM control with line and load CC compensation. The IC can achieve audio noise free operation and optimized dynamic response. The built-in Cable Drop Compensation (CDC) function can provide excellent CV performance. U6773S integrates functions and protections of Under Voltage Lockout (UVLO), VDD over Voltage Protection (VDD OVP), Cycle-by-cycle Current Limiting (OCP), Short Load Protection (SLP), and VDD Clamping. U6773S is available in SOP-7.
全部回复(2)
lgwxyx
能是汉语就好了。
@lgwxyx
能是汉语就好了。
 更多资料找  菲诺克科技  TEL:13600411241 QQ:3581165900,可帮画板
