用SC4519 12V转1.8V输出电压不对
两路DC-DC,用的是SC4519,12V-5V和12V-1.8V,调试中发现5V正常,有些板子1.8V那路输出电压不对,似乎是芯片坏了,更换芯片就好了,但是经常会出现这个问题,而且就出现在1.8V这路,不知为何?请各位高手指教!先谢了!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/54/747251180707887.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(7)
sunnychan
有没有人遇到过同样问题啊?
ao_power
@sunnychan
有没有人遇到过同样问题啊?
可以试用AOZ1014
了空
多大电流?可以换AOZ1011/1010/1014外部电路非常简单。
xjing
Hello,
If you can email me your circuit(your posting is not clear), I can check for you or give you some suggestions. If necessary I could try
to repeat your problem.
Best wishes,
Xiukuan Jing
my email: xjing6@yahoo.com
sunnychan
@xjing
Hello,Ifyoucanemailmeyourcircuit(yourpostingisnotclear),Icancheckforyouorgiveyousomesuggestions.IfnecessaryIcouldtrytorepeatyourproblem.Bestwishes,XiukuanJingmyemail:xjing6@yahoo.com
楼上的,谢了!附件为电路图! 747251181110374.pdf
xjing
@sunnychan
楼上的,谢了!附件为电路图!747251181110374.pdf
Sorry. I did not get back regularly.
The schematic seems ok.
dieghost
1 看看SW段开关脉冲波形,应该是周期方波,但是沿会有抖动,要求要求是方波,沿抖动不大,如果不满足,调整一下补偿电路,4519有些挑负载,把C323加大10倍看看效果
2 看自举电路工作是否正常
