找了半天,只有目录,那位有文档分享一下啦
Table of Contents for UL 8750
Outline Title Page
Table of Contents
Body
INTRODUCTION
1 Scope
2 General
2.1 Components
2.2 Units of measurement
2.3 Reference publications
3 Definitions
4 General Requirements And Use Of This Outline of Investigation
4.1 General
4.2 LED modules
CONSTRUCTION
5 Environmental Considerations
6 Mechanical Construction
6.1 General
6.2 Metal enclosures
6.3 Polymeric materials for enclosures and electrical insulation
6.4 Barriers
6.5 Conductor protection
6.6 Strain relief
7 Electrical Construction
7.1 General
7.2 Accessibility of hazardous live parts
7.3 Hazardous live parts other than exposed wiring terminals
7.4 Exposed wiring terminals
7.5 Internal wiring
7.6 Supply and load connections
7.7 Separation of circuits
7.8 Insulating materials
7.9 Printed wiring boards
7.10 Spacing of electrical parts
7.11 Circuit components
7.12 Protective devices
8 LED Power Source
8.1 General
8.2 Power source enclosure
8.3 Power supplies
8.4 Transformers
9 LED and Control Modules
9.1 General
9.2 Enclosures
9.3 Enclosure openings
9.4 Conditions of use for component LED and control circuit modules
PERFORMANCE
10 Performance Tests
10.1 General
10.2 Input test
10.3 LED module normal operations temperature test
10.4 Dielectric voltage withstand test
11 Abnormal Tests
11.1 General
11.2 Unreliable component abnormal test
11.3 50-W point power measurement test
MARKINGS
12 Markings
12.1 General
12.2 Required markings
APPENDIX A
LIGHT EMITTING DIODE (LED) LIGHT SOURCES FOR USE IN LIGHTING PRODUCTS
1 Scope
1.1 These requirements specify the minimum safety requirements for the component parts of a light emitting diode (LED) light source that serves as the source of illumination in any of the lighting products listed in 1.3.
1.2 An LED light source consists of one or more of the following component parts:
a) LED or LED array - that provide illumination,
b) Power source that supplies the proper voltage and current to operate the LEDs,
c) Control circuitry that may switch, dim or otherwise control the electrical energy to the LEDs.
1.3 LED light sources complying with these specifications are utilized as the source of illumination in lighting products that comply with the appropriate end product standard as listed below. These lighting products are intended for installation on branch circuits of 600 V nominal or less in non-hazardous locations in accordance with the National Electrical Code (NEC), ANSI/NFPA 70. These requirements also apply to LED light sources connected to isolated (non-utility connected) power sources such as batteries, fuel cells, and the like. Included are:
a) Luminaires, UL 1598;
b) Portable luminaires, UL 153;
c) Stage and studio luminaires, UL 1573;
d) Submersible luminaires, UL 676;
e) Swimming pool luminaires, UL 676;
f) Track lighting systems, UL 1574 ;
g) Signs, UL 48;
h) Emergency lighting and exit signs, UL 924;
i) Self-ballasted lamps, UL 1993;
j) Luminous Egress Path Marking Systems, UL 1994;
k) Nightlights, UL 1786;
l) Flexible lighting, UL 2388;
m) Low Voltage Lighting Systems, UL 2108;
n) Lampholder Fittings, UL 496; and
o) Landscape Lighting, UL 1838.
1.4 Applications incorporating LED light sources such as lighting products for use in hazardous locations, health care, emergency lighting or marine lighting have additional requirements not described in this outline of investigation.
LED照明新标准UL8750
全部回复(50)
深圳市红绿蓝光电科技有限公司
TOP LED: 3528、5050系列产品专业生产厂家,以下我司主导TOP 白光产品:
0.2W单芯3528 10-15LM 3000-3500MCD
0.5W单芯3528 20-25LM 5500-6500MCD
0.2W单芯5050 13-18LM 3500-4000MCD
0.5W单芯5050 25-30LM 6000-7000MCD
另外我司还有可以过回流焊的大功率LED,1W白光是90-100LM,3W白光是100-150LM,欢迎来电咨询!
E-mail: zhengwenhua1121@163.com
www.sunlight-led.com
Mobile: 15818500989 QQ:273078513
ADD:深圳石岩塘头路口宏发科技园D栋
ADD:深圳石岩塘头路口宏发科技园D栋
@zhengwenhua
深圳市红绿蓝光电科技有限公司TOP LED:3528、5050系列产品专业生产厂家,以下我司主导TOP白光产品: 0.2W单芯352810-15LM3000-3500MCD 0.5W单芯352820-25LM5500-6500MCD 0.2W单芯505013-18LM 3500-4000MCD 0.5W单芯505025-30LM6000-7000MCD 另外我司还有可以过回流焊的大功率LED,1W白光是90-100LM,3W白光是100-150LM,欢迎来电咨询! E-mail:zhengwenhua1121@163.com www.sunlight-led.comMobile:15818500989QQ:273078513From:郑先生ADD:深圳石岩塘头路口宏发科技园D栋
我也想要一份UL8750的标准,希望高手发一份给我
joky789@163.com
joky789@163.com
