急问:MBR6045的反向恢复时间是多少?
肖特基二极管
全部回复(6)
gwwater
手册上有
手册上有
@gwwater
手册上有手册上有
什么手册啊
帮我查一下
jacki_wang
LV.11
@gwwater
手册上有手册上有
手册上没有
1067570804.pdf
leodragon
我已帮你问安森美了,还没回复,估计很快!
我已帮你问安森美了,还没回复,估计很快!有消息我通知你!
huangcb
肖特基的DATASHEET没有反向恢复时间这一项!
我查过许多肖特基的DATASHEET,好象都没有反向恢复时间这一项.
leodragon
ON Semiconductor answer
安森美的回复,供参考:
We do not specify Trr for Schottky rectifiers. This is because Schottky
devices switch so quickly that many Trr test systems cannot accurately
record the time. We have tried to test Trr on Schottky devices before,
and the Trr ranged from below 10 nsec to around 35 nsec. This is just a
general Trr for Schottky devices, not for MBR6045WT which you asked
for."
