同步整流
请问各位大侠,怎样用场管做同步整流?还有用同步整流有何好处?
全部回复(7)
1. In most of case, you will need a Sync. rectifier IC, such as ANA-CHIP 436. althrough, you can just use two MOS to make sync. rec. but not worthwhile.
2. Use Sync. IC you may improve the efficiency 2~2.5%approximately, without (use two MOS only), you may improve the efficiency about 1% or so only.
There is a new company that is focus on the Synchronous recetifier contorl IC , you could check the website first !
www.syncpower.com
There is some technology document for you , then you could have the request to their sales about the sample testing !
Check the website , you will get more and more !
www.syncpower.com
@gavinliao
ThereisanewcompanythatisfocusontheSynchronousrecetifiercontorlIC,youcouldcheckthewebsitefirst!www.syncpower.comThereissometechnologydocumentforyou,thenyoucouldhavetherequesttotheirsalesaboutthesampletesting!Checkthewebsite,youwillgetmoreandmore!
兄弟们,能用国语吗?我的英语不怎样?见笑了!!!
