全桥串联谐振电磁感应加热试验的波形.
igbt没有吸收电路.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/56/237231187823683.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
驱动频率等于谐振频率占空比最大时的驱动和电流波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/56/237231187823924.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
驱动频率等于谐振频率占空比最大时的驱动和igbt电压波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/56/237231187824158.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
驱动频率等于谐振频率占空比减小时的驱动和电流波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/56/237231187824819.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
驱动频率等于谐振频率占空比减小时的驱动和igbt电压波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/56/237231187824291.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
最大占空比频率升高时(高于谐振频率)的驱动和电流波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/56/237231187824481.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
最大占空比频率升高时的驱动和igbt电压波形
驱动频率等于谐振频率占空比最大时的零电流开关最好,关断还是零电压.随占空比减小关断电流加大,关断也不是零电压了.
随频率升高关断也不再是零电流.
可见igbt开关损耗在驱动频率等于谐振频率占空比最大时.
试验中电流互感器制作有困难,试验了几种磁芯选了一个效果较好点的
波形还是有些崎变.二次圈数少崎变大.圈数多电压高.试验中用的滤波电容为10uf.电源220v.当满电压时,功率达到9kw.电流互感器二次电压很高,负载电阻(4.7k)很快烧毁了.
试验在继续中......
全桥串联谐振电磁感应加热试验
全部回复(41)
@luyuc
顶电流互感器检流电阻不能大于1欧,否则将引起过大功耗;从电压波形上来看,调谐还算过的去,;从电流波形上看来,谐振电容上的电压太低,也就是设定Q值太低,电流波形偏离良好的正玄波太远,应当减小电容,重新调谐,我期待看到一个很好的正玄波电流,在大的荷载下; luyuc
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/56/237231187955441.jpg');}" onmousewheel="return imgzoom(this);">
电流互感器负载电阻为10欧姆的电流波形.相机暴光时间长相机有些抖动.
@秋天的风
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/56/237231187955441.jpg');}"onmousewheel="returnimgzoom(this);">电流互感器负载电阻为10欧姆的电流波形.相机暴光时间长相机有些抖动.
dd
@秋天的风
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/57/237231188910416.jpg');}" onmousewheel="return imgzoom(this);">
304不锈钢加热体半桥单相8kw电流波形(10uf滤波电容).
@秋天的风
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/57/237231188910416.jpg');}"onmousewheel="returnimgzoom(this);">304不锈钢加热体半桥单相8kw电流波形(10uf滤波电容).
塑料机用的感应加热你应该能适应阿,以前咱们讨论过一次,用继电器投切多组控制,就是你的方案,这次讨论就是塑料机上的多组应用阿!
@秋天的风
这真是好波形阿,只要加上关断钳位就不怕逆程反射能量了
@luyuc
这个我觉得不太认同,如果要得到同样幅值的电流采样波形Ui=Io/n*R,显然减小采样电阻R就必须相应的提高Io/n,Io是被测电流不能改变,只能改变互感器的变比n,则采样电阻损耗P=Ui*Ui/R=Io*Io/(n*n)*R 是增加的,所以要减小采样电阻功耗只能是增加变比n,再选取适当的采样电阻.
@camm3219
电流互感器检流电阻不能大于1欧,否则将引起过大功耗;这个我觉得不太认同,如果要得到同样幅值的电流采样波形Ui=Io/n*R,显然减小采样电阻R就必须相应的提高Io/n,Io是被测电流不能改变,只能改变互感器的变比n,则采样电阻损耗P=Ui*Ui/R=Io*Io/(n*n)*R 是增加的,所以要减小采样电阻功耗只能是增加变比n,再选取适当的采样电阻.
最好的办法是采用双二极管(正反并联)做电流互感器负载,好处有很多.
1.极大地提高Io很小时候的检测灵敏度,相当于增大了动态范围.
2.极大地减小了Io很大时后的功耗,相当于很小的电阻.
3.在电流发生变化时,也能输出比较完美的方波.如后面接PLL IC CD4046,那么14脚的放大器放大倍数为400倍,如使用低阻Rs,Io很小时Vs也很小,那么就会产生相当大的相位延迟,造成频率误差.由于是电流相位滞后了,那么主回路电流相位就会超前进入容性状态,这个是很危险的工作状态.那如果使用二极管做负载,那么不管电流如何变化,都可以得到小而稳定的相位差,就不会发生频率抖动.具体见帖:CD4046与PWM IC的连接.
