SABER里MC34063A模型有错
我来弄一个34063仿真探讨,有问题的来这里发言.把原理图一起贴上来(我有正确的模型.)
全部回复(12)
@hehe
我上传一个比较简单的参数计算公式和原理图1105067088.zip
这是计算叶面
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/25/1105067190.gif');}" onmousewheel="return imgzoom(this);">
@hehe
这是计算叶面[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/25/1105067190.gif');}"onmousewheel="returnimgzoom(this);">
这是原本的模型,我看不出哪里错?
#VERSION /component/pwm/acl/pwm_1/mc34063a.dec@@/main/1
#DATED Wed Jun 9 12:05:25 PDT 1999
# This template created by Analogy, Inc. *
# for exclusive use with the Saber(R) simulator. *
# Saber is a registered trademark of American Airlines, licensed *
# to Analogy Inc. Copyright 1989-1999, Analogy Inc. *
# This template may not be reproduced in any way (physically or *
# electronically) without permission from Analogy, Inc. The *
# content of this template is subject to change without notice. *
# Analogy does not assume liability for the use of this template *
# or the results obtained from using it. *
encrypted component template mc34063a vcc gnd drv_c sw_c sw_em ct ipk \
inv_comp= ratings, rth_ja, rth_jc, rth_hs, part_type, part_class
######################### USAGE NOTES AND CAUTIONS ####################
# Ratings information
pwmtype..ratings ratings =
(tjmax = 70,
tjmin = 0,
pdmax_ja = 1.25e+00,
pdmax_jc = 3.00e+00,
vccmax = 40,
vinmin = -0.3,
vinmax = 40,
dvinmax = undef,
vin2max = undef,
voutmax = undef,
ioutmax = 2.00e-01,
vformax = undef,
vformin = undef,
vpwrgnd = undef,
iformax = undef,
irefout = 5.00e-02,
isoftmax = 5.00e-02,
ieaout = 5e-3,
isynout = 5e-3,
ioscout = 5e-3,
ioscchg = undef)
number rth_ja = 100,
rth_jc = 2,
rth_hs = undef
string part_type = "PWM"
string part_class = "Voltage Mode"
export val p pwrd
export val tc tempj
external number temp, include_stress
# Manufacturer information
pwm_info..mfr_info mfr_info =
(mfr_part_num = "MC34063A",
libs = [dxocl],
config = single,
num_of_outputs = 1,
pkg = pdip_8,
mfr = moto)
# Manufacturer specification
pwm_info..mfr_specs mfr_specs =
(freq_max = 100e3,
tol_vref = 2,
duty_max = 95)
(tjmax = 70,
tjmin = 0,
vccmax = 40,
vinmin = -0.3,
vinmax = 40,
dvinmax = undef,
vin2max = undef,
voutmax = undef,
ioutmax = 2.00e-01,
vformax = undef,
vformin = undef,
vpwrgnd = undef,
iformax = undef,
irefout = 5.00e-02,
ieaout = 5e-3,
isynout = 5e-3,
ioscout = 5e-3,
ioscchg = undef)
rth_jc = 2,
rth_hs = undef
export val p pwrd
export val tc tempj
libs = [dxocl],
config = single,
num_of_outputs = 1,
pkg = pdip_8,
mfr = moto)
(freq_max = 100e3,
tol_vref = 2,
duty_max = 95)
@lpf123
这是原本的模型,我看不出哪里错?#VERSION/component/pwm/acl/pwm_1/mc34063a.dec@@/main/1#DATEDWedJun912:05:25PDT1999#*********************************************************************# ThistemplatecreatedbyAnalogy,Inc. *# forexclusiveusewiththeSaber(R)simulator. *# SaberisaregisteredtrademarkofAmericanAirlines,licensed *# toAnalogyInc. Copyright1989-1999,AnalogyInc. *# Thistemplatemaynotbe reproducedinanyway(physicallyor *# electronically) withoutpermission fromAnalogy, Inc. The *# content ofthistemplateissubjecttochangewithoutnotice. *# Analogydoesnotassumeliabilityfortheuseofthistemplate *# ortheresultsobtainedfromusingit. *#*********************************************************************encryptedcomponenttemplatemc34063avccgnddrv_csw_csw_emctipk\inv_comp=ratings,rth_ja,rth_jc,rth_hs,part_type,part_class#########################USAGENOTESANDCAUTIONS#############################################################################################Ratingsinformationpwmtype..ratingsratings= (tjmax=70, tjmin=0, pdmax_ja=1.25e+00, pdmax_jc=3.00e+00, vccmax=40, vinmin=-0.3, vinmax=40, dvinmax=undef, vin2max=undef, voutmax=undef, ioutmax=2.00e-01, vformax=undef, vformin=undef, vpwrgnd=undef, iformax=undef, irefout=5.00e-02, isoftmax=5.00e-02, ieaout=5e-3, isynout=5e-3, ioscout=5e-3, ioscchg=undef)number rth_ja=100, rth_jc=2, rth_hs=undefstringpart_type="PWM"stringpart_class="VoltageMode"exportvalp pwrdexportvaltctempjexternalnumbertemp,include_stress{#Manufacturerinformationpwm_info..mfr_infomfr_info= (mfr_part_num="MC34063A", libs=[dxocl], config=single, num_of_outputs=1, pkg=pdip_8, mfr=moto)#Manufacturerspecificationpwm_info..mfr_specsmfr_specs= (freq_max=100e3, tol_vref=2, duty_max=95)
在模型里面,有个地和Vin接在一起了.
在仿真的时候波形不会正常的,自己试试吧.
saber公司总部给了一个正确的模型给我门公司.
@lpf123
#VERSION mt_component/pwm/acl/pwm_2/mc34063a.dec@@/main/2
#DATED 07-Dec-2004.22:20:30
# Copyright 2004 Synopsys Inc. #
# This template and the associated documentation are #
# confidential and proprietary to Synopsys, Inc. #
# Your use or disclosure of this template is subject to #
# the terms and conditions of a written license agreement #
# between you, or your company, and Synopsys, Inc #
(tjmax = 70,
tjmin = 0,
vccmax = 40,
vinmin = -0.3,
vinmax = 40,
dvinmax = undef,
vin2max = undef,
voutmax = undef,
ioutmax = 2.00e-01,
vformax = undef,
vformin = undef,
vpwrgnd = undef,
iformax = undef,
irefout = 5.00e-02,
ieaout = 5e-3,
isynout = 5e-3,
ioscout = 5e-3,
ioscchg = undef)
rth_jc = 2,
rth_hs = undef
export val p pwrd
export val tc tempj
libs = [dxocl],
config = single,
num_of_outputs = 1,
pkg = pdip_8,
mfr = moto)
(freq_max = 100e3,
tol_vref = 2,
duty_max = 95)
(tjmax = 70,
tjmin = 0,
vccmax = 40,
vinmin = -0.3,
vinmax = 40,
dvinmax = undef,
vin2max = undef,
voutmax = undef,
ioutmax = 2.00e-01,
vformax = undef,
vformin = undef,
vpwrgnd = undef,
iformax = undef,
irefout = 5.00e-02,
ieaout = 5e-3,
isynout = 5e-3,
ioscout = 5e-3,
ioscchg = undef)
rth_jc = 2,
rth_hs = undef
export val p pwrd
export val tc tempj
libs = [dxocl],
config = single,
num_of_outputs = 1,
pkg = pdip_8,
mfr = moto)
(freq_max = 100e3,
tol_vref = 2,
duty_max = 95)
@carhid
#VERSIONmt_component/pwm/acl/pwm_2/mc34063a.dec@@/main/2#DATED07-Dec-2004.22:20:30#**********************************************************************## Copyright2004SynopsysInc. ## Thistemplateandtheassociateddocumentationare ## confidentialandproprietarytoSynopsys,Inc. # # Youruseordisclosureofthistemplateissubjectto ## thetermsandconditionsofawrittenlicenseagreement ## betweenyou,oryourcompany,andSynopsys,Inc ##**********************************************************************#encryptedcomponenttemplatemc34063avccgnddrv_csw_csw_emctipk\inv_comp=ratings,rth_ja,rth_jc,rth_hs,part_type,part_class#########################USAGENOTESANDCAUTIONS#############################################################################################Ratingsinformationpwmtype..ratingsratings= (tjmax=70, tjmin=0, pdmax_ja=1.25e+00, pdmax_jc=3.00e+00, vccmax=40, vinmin=-0.3, vinmax=40, dvinmax=undef, vin2max=undef, voutmax=undef, ioutmax=2.00e-01, vformax=undef, vformin=undef, vpwrgnd=undef, iformax=undef, irefout=5.00e-02, isoftmax=5.00e-02, ieaout=5e-3, isynout=5e-3, ioscout=5e-3, ioscchg=undef)number rth_ja=100, rth_jc=2, rth_hs=undefstringpart_type="PWM"stringpart_class="VoltageMode"exportvalp pwrdexportvaltctempjexternalnumbertemp,include_stress{#Manufacturerinformationpwm_info..mfr_infomfr_info= (mfr_part_num="MC34063A", libs=[dxocl], config=single, num_of_outputs=1, pkg=pdip_8, mfr=moto)#Manufacturerspecificationpwm_info..mfr_specsmfr_specs= (freq_max=100e3, tol_vref=2, duty_max=95)
谢了,但看不出有啥区别啊!
@carhid
是不对,你的是正确的吗?
@carhid
这个是正确的吗?
