求助ML4800 一段精华部份翻译
The gain vs. input voltage of the ML4800’s
voltage error amplifier has a specially shaped non-linearity such that under steady-state operating conditions the transconductance of the error amplifier is at a local minimum.
全部回复(1)
alpha
大意是:ML4800电压误差放大器的增益-输入曲线图有一个特别的非线性形状,在稳定工作状态下,误差放大器的跨导有一个局部最小值.
