各位DX,根据IEC60335对限温器的定义如下:
temperature limiter
temperature-sensing device, the operating temperature of which may be either fixed or adjustable and which during normal operation operates by opening or closing a circuit when the temperature of the controlled part reaches a predetermined value
NOTE It does not make the reverse operation during the normal duty cycle of the appliance. It may or may not require manual resetting.
请问备注栏中的"reverse coperation"该如何理解呢?是否指"如果在正常工作状态下,限温器断开,是不可以自己自动动作重新联通的".请有经验的dx指教.谢谢
