翻译.谢谢!!!
操纵杆向前,后,左,右方向摆动最大幅度为一个循环, 共测试1000次循环.如果操纵杆在测试过程中出现不能定位, 且不能定位角度大于10度或完全不能定位,则属不合格.
谢谢!!!!!!
全部回复(2)
liuwq1988
Manipulate a pole forward, after, left, right to swing the most significant is a circulating, test 1000 circulations totally.If manipulate a pole during the period of testing appear can't position, and can't position more than 10 degrees of angles or can't position completely, then is unqualified
@liuwq1988
Manipulateapoleforward,after,left,righttoswingthemostsignificantisacirculating,test1000circulationstotally.Ifmanipulateapoleduringtheperiodoftestingappearcan'tposition,andcan'tpositionmorethan10degreesofanglesorcan'tpositioncompletely,thenisunqualified
over..
