最新車載/DC--ATX電源展示
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/63/1332771204336752.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">产品型号:PPM-12-120 DC/DC ATX power supply for automobile application, 12VDC input. 5V, 12V, 3.3V,-12V, 5VSB and PG (power good signal) outputs. 规格: 1.The smallest 12V DC to DC power supply 2. convertor in the world. 3.Adopt industrial solid capacitor, ideal for being used in 4. harsh evironment 5.High performance with high heat-stand feature, more realiable 6.Fanless DC-DC solution for 100% mute operating . 7.Compact design, special for mini-itx and 1U case. Output Voltage Regulation Output Min Load(A) MAX Load(A) Regulation 12V 0.1 6 ±5% 5V 0.1 5 ±5% 3.3V 0.1 5 ±5% -12V 0 0.1 ±15% 5VSB 0.1 1 ±5% 参数: 1.Dimensions(mm): L43x W38x20H 2.DC Input: 12V 3.DC Output : 120W 4.Input Current: Max. 15A 5.Efficiency: above 92% 6.MTPF: 100,000H 7.Operating Temperature: 0℃ ~ 60℃ 8.Storage Temperature: -40℃ ~ 70℃ 500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/63/1332771204336804.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);"> 产品型号:PPT-12-90 DC/DC ATX power supply for automobile application, 12VDC input. 5V, 12V, 3.3V,-12V, 5VSB and PG (power good signal) outputs. 规格: 1.The smallest 12V DC to DC power supply 2. convertor in the world. 3.Adopt industrial solid capacitor, ideal for being used in 4. harsh evironment 5.High performance with high heat-stand feature, more realiable 6.Fanless DC-DC solution for 100% mute operating . 7.Compact design, special for mini-itx and 1U case. Output Voltage Regulation Output Min Load(A) MAX Load(A) Regulation 12V 0.1 4.5 ±5% 5V 0.1 4.5 ±5% 3.3V 0.1 4.5 ±5% -12V 0 0.1 ±15% 5VSB 0.1 1 ±5% 参数: 1.Dimensions(mm): L37x W23.6x17H 2.DC Input: 12V 3.DC Output : 90W 4.Input Current: Max. 15A 5.Efficiency: above 92% 6.MTPF: 100,000H 7.Operating Temperature: 0℃ ~ 60℃ 8.Storage Temperature: -40℃ ~ 70℃
