大功率管 铁帽
2SC3990 2SC3991 2SC3993 2SC3994 2SC3995 2SC3996 2SC3997 2SC3998 2SC5047 2SC5142 2SC3714 2SC5445 2SC5446 2SC5243 2SC5244 2SC5570 2SC5144 2SC5422 2SC5612 2SC4928 25U40 2SD2356 2SD1525 2SD2428 2SD1313 2SD1314 2SC3738 2SC3989 2SC5381A 2SC4096 2SC5589 2SC3307 2SC4119 2SC4111 2SC5331 2SC5301 2SC5573 2SC4290 2SC4288 2SC4897 2SC5583 2SC5584 2SC5597 2SC5859 2SC3489 2SC3499 J6820 J6920 J6825 HPA100 HPA150 BU2532AL BU2530AL BU4530AL MJL16218 2SA1908 2SC5100 2SC4278 2SA1633 2SA1746 2SC4131 MJL21193 MJL21194 MJL4281A MJL4302A 2SD1975 2SB1317 2SD2222 2SB1470 2SD2254 2SB1492 2SD2275 2SB1490 2SD2276 2SB1594 2SD2250 2SB2029 2SB1429 2SD2155 2SA1301 2SC3280 2SA1302 2SC3281 2SA1943 2SC5200 2SA1215 2SC2921 2SA1216 2SC2922 2SA1295 2SC3264 2SA1494 2SC3858 2SA1553 2SC4029 2SA1094 2SC2564 2SA1940 2SC5197 2SA1941 2SC5198 2SA1962 2SC5242 2SA1986 2SC5358 2SA1491 2SC3855 2SA1693 2SC4466 2SA1694 2SC4467 2SC2774 2SC2773 2SC2565 2SA1095 2SC2625 2SB755 2SD845 2SA1170 2SA1169 2SB1429 2SA1987 2SC5359 MN1715 MP1715 2SA1303 2SC3284 2SA1205 2SC3300 2SD1047 2SB817 2SA1106 2SC2581 2SA1264 2SC3181 2SA1265 2SC3182 2SA1516 2SC3907 2SA1695 2SC4468 2SA1490 2SC3854 2SA1303 2SC3284 2SA1492 2SC3856 2SA1294 2SC3263 2SA1186 2SC2837 2SA1386 2SC3519 2SA1987 2SC5359 2SA1075 2SC2525 2SB778 2SD998 2SD718 2SB688 2SD845 2SB755 2SK339 2SJ113 2SJ161 2SK1057 2SJ162 2SK1058 2SJ118 2SK413 2SJ114 2SK400 2SD1559 2SB1079 2SD2256 2SB1494 2SD1435 2SB1031 2SD1436 2SB1032 2SD1110 2SD1210 2SD1298 2SA2987 2SD1018 2SA1227 2SK794 2SK724 2SK795 2SK725 2SK727 2SK787 2SK1271 2SK1916 2SK1120 2SK1169 2SK1170 2SK1796 2SK790 2SK793 2SK1795 2SK1794 2SK2611 2SK1358 2SK447 2SK539 2SK1489 2SK578 2SK1681 2SK2198 2SK2698 2SK2077 2SK2847 2SK1363 2SK1539 2SK1544 2SK1082 2SK2057 2SK2828 2SK1464 2SK2370 2SK2372 2SK2375 2SK2368 2SK685 2SK1757 2SK2837 2SK1382 2SK1520 2SK1522 2SK1837 2SK1527 2SK386 2SK2039 2SK2038 2SK850 2SK851 2SK1018 2SK1168 2SK1180 2SK1181 2SK1020 2SK1019 2SK1947 2SK1629 2SK2343 2SK2257 2SK1466 2SK2267 2SK3235 2SK1248 IRFPE30 IRFPE40 IRFP044 IRFP064 IRFP150 IRFP250 IRFP450 IRFP350 IRFP460 IRFP441 IRFP360 IRFP240 IRFP9240 IRFP260 IRFP254 IRFP264 IRG4PC30S IRG4PC50 IRG4PH40U IRG4PH50U IRG4PH50UD IRG4PH50F IRG4PC40F IRGP20B120U IRGP30B120K 30G120W IRGPS40B120U 2SC3164 2SC3460 2SC3461 2SC3153 2SC5086 2SC4747 2SC5250 2SC5251 2SC5252 2SC5124 2SC5132A 2SC5447 2SC5448 2SC5449 2SC4589 2SD2148 2SC4297 2SC5150 2SC4542 2SC5296 2SC5297 2SC5298 2SC5299 2SC5148 2SC5149 2SC4761 2SC4762 2SC5003 2SC5002 2SC5203 2SC5404 2SC5045 2SC5703 2SC4890 2SC4891 2SC4430 2SC5587 2SC5855 2SC5068 2SC4770 2SC4428 2SC4429 2SC5801 2SC5802 2SC5803 2SC5088 2SC4763 2SC4199 2SC5044 2SC4300 2SC3883 2SD1453 2SD1455 2SC3320 2SC3505 2SC3506 2SC3507 2SC3737 2SD1457A 2SC3833 2SC5071 2SC4138 2SC4139 2SC5352 2SC2625 NT2625 2SB828 2SD1496 2SC2749 2SC2750 2SC2751 2SC3300 2SC3552 2SC4923 2SC4924 2SC4581 2SC4582 2SC4585 2SC4584 2SD2445 2SD1399 2SD1398 2SD1397 2SD1396 2SD2331 2SD1441 2SD1294 2SD1911 2SD1541 2SD1959 2SD1941 2SD2095 2SD2125 2SD2454 2SD1545 2SD2586 2SD2500 2SD1547 2SD1548 2SD2057 2SD2348 2SD1885 2SD1886 2SD1887 2SD1880 2SD1881 2SD1877 2SD1878 2SD1879 2SD1651 2SD1652 2SD1882 2SD5072 2SD2578 2SD2498 2SD2499 2SD1710 2SD1711 BU2508A 2SC5681 2SC5451 2SC4199 2SD2251 TS7910 TS7988 TT2064 TT2062 2SD2634 2SD1554 2SD1555 2SD1556 2SD1849 2SD1850 2SD1847 2SD2064 2SB1361 2SD1632 2SB1663 2SD3212A 2SC2834A 2SD2333 2SD2334 2SD2335 2SD1576 2SD1577 2SD2539 2SC3886 2SC3886A 2SC5129 2SC5411 2SC5339 2SC5280 2SC3679 2SC3680 2SC3152 2SC3688 2SC3306 2SC2555 2SC4123 2SC4124 2SC4125 2SD2253 2SD2553 2SC4916 2SC4423 2SC4424 2SD1739 2SC5386 2SC5387 2SC4236 2SC4237 2SC4706 2SC4927 2SD2581 2SD1402 2SD1403 2SC3210 2SD5048 2SC5440 2SC5302 2SC3892A 2SC3893A 2SC3894 2SC3895 2SC3897 2SC5388 2SC4762 2SC1425 2SC1426 2SC1427 2SC1428 2SD1431 2SC4302 N12030 MN650 BU508A BU508D HPA72 FN521 2SH16 FK25SM-6 2SC3835 2SC2073 2SA940 BT151 2SC5586 2SC5902 2SC5909 2SC5520 2SC5521 2SC5622 2SC5515 2SC5478 2SC5418 2SC5414 2SC5424 2SC5294 2SC5423 2SC5440 2SC5207A 2SC2524 2SC5270A 2SC5406A 2SC5380 2SC5407 2SC5480 2SC5380 2SC5546 2SC5572 2SC2572 2SC2521 2SC5516 2SC5517 2SC5552 2SC5904 2SC5905 2SC5914 2SC5936 2SC5928 2SC5929 J6812 J6815 J6910 J5804 J6810 J6916 J6820 2SD1488 2SD1672 2SC2793 2SC2615 2SD1037 2SD1038 2SD1036 MKV670 IXFB70N60Q2 IXSK35N120 IXGX50N60 IXFR55N50 IXFK48N50 IXFH58N20 IMBH25-120 IMBH25D-120 TY30N50E SMW70N06-14 1M30D-060 GT40Q321 GT40Q322 GT40Q323 GT8J101 GT15J101 GT15Q101 GT25J101 GT30J322 GT40M101 GT50J101 GT50J102 GT50J301 GT50J322 GT50J325 GT60J323 GT80J101 GT50M101 GT60M301 GT60M104 GT60M303 GT60M322 GT60M321 GT60M101 GT60M102 GT25Q101 GT60N321 GT40T101 GT40T301 GT50T101 RM25HG24S FGL40N150D G40N150 1MBH65D-090A 1MBH60-100 1MBH60-170 1MBH65-100 1MBH30D-060 1MBH15D-060 1MBH20D-060 47N60C3 50N50 MTY20N50E MTY25N60E FGA15N120 K15T120 H15T120 H20T120 H20R120 FGA25N120 SGW25N120 G27N120BN G25N120 G30N60 G80N60 100N10 CC1029 N6050 G60N90 1XTK62N25 1XFH58N20 1XFH75N10 1XFH18N120 1XFH27N120 CT60AM20 CT60AM18 MG60M1AL1 MG30T1AL1 1MG50-090A.B 5N5016 5N6001 5N2503 BUH515D BUH515 BUH715D BUH1015HI BUH315D FS7SM16A FS10SM16A FS14SM18A FS18SM10A QM5HL-24 QM5HG-24 ON4409 ON4873 BU2525AF BU2527AF BU4525AF BU4522AF BU2515AF BU2722AF BU2520AF BU2520DF BU508AF BU2508AF BU2508DF BU2523AF BU2708AF BU2522AF BU2527AX BU2520AX BU2520DX BU2507AX BU2507DX BU2522AX BU4508AX BU4508DX BU2523AX BU4525AX BU2515DX BU4515AX BU2508AX BU2508DX BU4522AX BUW12AF 610597 BUW12A BUF420 BU426 BU1215 BU2525 BU2508A BU508A BUW48B MJH16010 MJ16012 25F8817 TIP35C MJW16212 BU2532AW BU4530AW 2N3055 MJ2955 2SC1116 2SC1115 2SA747 2SA746 IRF250 IRF240 2SC1871 LM317K LM338K LM350K LM337K 2SA1072 2SC2522 2SA1073 2SC2523 2SD670H 2SB650H MJ1009 MJ4502 MJ11032 MJ11033 MJ15003 MJ15004 MJ11015 MJ11016 MJ15023 MJ15024 MJ13333 2SC1942 2N6339 BU208A 2SD797 STR440 LM78H05 2SC3058 2SC2245 2SC2246 ETE01-040B BUS13A BUS14A BUX48A FT5754M STR450 STR451 STR455 STR456 STR457 STR459 2SD850 2N6678 2SD555 2SB600 2SJ217 D20LC20 3102V 3052V 3522V 3122V ET190 ET191 2SD1049 TPDV1240 TIPL765A
散新原装   长期供应   价格有优势
WWW.LEKEDZ.COM
全部回复(4)
renad
能不只供样品,价格怎样?我想要2SK1271,10只.
email:raddn@sohu.com,有兴趣回复下
@renad
能不只供样品,价格怎样?我想要2SK1271,10只.email:raddn@sohu.com,有兴趣回复下
你好 你要10个  一个15元  有需要再联系 13510494997
renad
@星枫科技
你好你要10个  一个15元  有需要再联系13510494997
太贵了,如果批量还是这个价,我趁有时间改方案.
@renad
不是    批量价是9.5  样片价是15元    因为这个是寄货的  就贵了点
