可替代BP1360的拼对拼 华润矽威PT4211质量优的恒流驱动方案
一:方案名称:华润矽威PT4211
二:方案品牌:华润矽威
三:方案功能及特点
GENERAL DESCRIPTION The PT4211 is a continuous conduction mode inductive step-down converter, designed for driving single or multiple
 series connected LEDs from a voltage source higher than the LED voltage. The device operates from an input supply between 5V and 30V and
 provides an externally adjustable output current of up to 350mA. The PT4211 includes the output switch and a high-side output current sensing
 circuit, which uses an external resistor to set the nominal average output current, and a dedicated DIM input accepts a wide range of
 pulsed dimming. Applying a voltage of 0.4V or lower to the DIM pin turns the output off and switches the device into a low current standby
 state. Built-in Soft Over Temperature Protection protects the device from over temperature damage. The PT4211 is available in SOT23-5
package. FEATURES
 Simple low parts count
 Wide input voltage range: 5V to 30V
 Up to 350mA output current
 PWM dimming
 3% output current accuracy.
 Up to 1MHz switching frequency
 Typical 3% output current accuracy
 Inherent open-circuit LED protection
 High efficiency (up to 93%)
 Adjustable Constant LED Current
 High-Side Current Sense
 Hysteretic Control: No Compensation
 Soft Over Temperature Protection
APPLICATION
  Low voltage halogen replacement LEDs
 Automotive lighting
 LED back-up lighting
 Illuminated signs
Have need to contact a friend to the father WeChat LG1105023765 qq1105023765 provide complete data reference, have the original factory technical support
全部回复(0)
