仿真一开始电源用的220幅值。得到的波形很好,然后看了设计要求改成311幅值了然后就出现这样
The no_ramping algorithm failed. Trying the dyn_ramping algorithm.
Succeeded with the dyn_ramping algorithm.
execution time= 0.0781 sec.
*** ERROR "ALG_OUT_OF_REGIONS" *** /uc3854.uc3854_1/vint(op1h.2) is out ofdefined sample points on the low end.
*** ERROR "BUG_ASSERT_FAILED" *** Program failure at line 930 in file tran.r.Notify Synopsys, Inc.
restore
Partial results at time=0.002010702454828 were written to the initial point "tr".
execution time= 0.0625 sec.
messages given: 3 errors大佬们看看什么原因吧
