The MST56XXB series is a high voltage ,ultralow-power regulator.
(MST56XXB系列是一个高电压,超低功耗电压调节器。)
The device can allows an input voltage as high as 60V.
(该设备可以允许输入电压高达60V。)
The typical quiescent current is only 2µA.
(典型的静态电流只有2µa)
The device is available in fixedoutput voltages of 3.3V and 5.0V.
(该装置具有3.3V、5.0V固定输出电压。)
The device features integrated short-circuit andthermal shutdown protection.
(该设备具有集成短路和热关机保护功能。)
Although designed primarily as fixed voltageregulators, the device can be used with externalcomponents to obtain variable voltages.
(虽然设计主要是作为固定电压调节器,但该装置可以与外部元件一起使用,以获得可变电压。)
产品特点:Low Quiescent Current(低静态电流): 2μA
High Input Voltage(高输入电压): Up to 60V
High Output Current(高输出电流): ≥100mA
Dropout Voltage(压差)0:70mV@10mA700mV@100mA
Fixed Output Voltages(固定输出电压): 3.3V and 5.0V
High-accuracy Output Voltage(高精度输出电压)
MST 56XXB ±2%
Good Transient Response(良好的瞬态响应)
Integrated Short-Circuit Protection(集成短路保护)
Integrated Thermal Protection(综合热保护)
Available Packages:
具体信息请查看以下文档:/upload/community/2019/07/05/1562301219-73512.pdf
