【应征入伍】恒压60W 24V2.5A 应用方案 完美PIN对0B2263
  General DescriptionLZC9205 is a high performance, current modePWM controller. It provides functions of lowstart-up current, fast start-up, fixed switchingfrequency. Those features make it to achievehigh efficiency and low standby power witheffective system cost.At heavy load, the LZC9205 operate in fixedswitching frequency. At light load condition, thesystem operates in green mode for highefficiency. And at zero load, the IC will operate inBURST mode to enhance power saving.The LZC9205 offers comprehensive protectionto prevent the circuit from damage underabnormal conditions. Furthermore, the LZC9205features frequency swapping and soft drivingfunction to minimize the noise and improve EMIperformance.The LZC9205 is offered in SOT23-6 package.Features Internal Soft Start Fixed 67KHz Switching Frequency CCM @ Heavy Load and Low Line Green mode reduces frequency @Light Load Burst Mode @ No Load VDD Over voltage protection Cycle by cycle current limit Second level over current protection Output over voltage protection (OVP) Output short protection (SCP) Over Load protection (OLP) External precision OTPApplications Switching AC/DC power adapter SMPS Power Supply
全部回复(6)
9205 恒压方案 单颗可达120W  搞定各个功率段
@我要开大了
9205恒压方案单颗可达120W 搞定各个功率段
恒压24W-120W通用方案
@我要开大了
恒压24W-120W通用方案
菱奇一级代理 LZC9205  全压单颗120W恒压隔离方案
@我要开大了
菱奇一级代理LZC9205 全压单颗120W恒压隔离方案
LZC8660 特点脉宽调制,模拟调光 高PF,隔离,低谐波 最大功率120W 支持数字模拟调光 调光区间从3%-100% 0亮度关机 应用场合: 商业照明(0到10V调光) 智能照明 蓝牙 WIFI 红外线 2.4G
LZC8650 特点高精度温度电流折返功能 高PF,隔离,低谐波 最大功率120W 可编程输入过压保护 低成本可编程4档恒温转折点 145度 120度 100度 90度 应用场合(输入变化大,等环境恶劣场合) 船用照明 印度,东南亚等恶劣市电条件 工矿,塔吊灯等
@户外照明方案
LZC8660特点脉宽调制,模拟调光高PF,隔离,低谐波最大功率120W支持数字模拟调光调光区间从3%-100%0亮度关机应用场合:商业照明(0到10V调光)智能照明蓝牙WIFI红外线2.4G LZC8650特点高精度温度电流折返功能高PF,隔离,低谐波最大功率120W可编程输入过压保护低成本可编程4档恒温转折点145度120度100度90度应用场合(输入变化大,等环境恶劣场合)船用照明印度,东南亚等恶劣市电条件工矿,塔吊灯等
方案:非隔离、高PF、LZC8710自主设置温度(无误差1-100W方案)品牌: 美国菱奇特点:电流精度高、THD值小于10%,效率高在90%,性能稳定。可根据自己的需求设置温度140或130或90.等等,温控精准,基本不会出现误差,功率大小由外置MOS控制输入电压90-280VAC全单压通知,性价比高适用:球泡灯。天花灯,筒灯 工矿灯 防爆灯 路灯等LED灯具
@户外照明方案
发一下资料给我看一下1843524892@qq.com
