  • 论坛首页
  • 产品/供求资讯
  • EMP8733,EMP8734,EMP8130-300mA LDO(SOT-23-5,uDFN-4, SC-70-5, SC-82-4, TSOT-23-5, SOT-23-3,TDFN-6,±1% output voltage tolerance)
EMP8733,EMP8734
EMP8130-Ultra High-PSRR, Low-Noise, 300mA CMOS Linear Regulator
General Description
 The EMP8130 features ultra-high power supplyrejection ratio, low output voltage noise, lowdropout voltage, low quiescent current and fasttransient response. It guarantees delivery of 300mAoutput current and supports preset output voltagesranging from 0.8V to 4.0V with 0.1V increment.Based on its low quiescent current consumption andits less than 1uA shutdown mode of logical operation,the EMP8130 is ideal for battery-poweredapplications. The high power supply rejection ratioof the EMP8130 holds well for low input voltagestypically encountered in battery-operated systems.The regulator is stable with small ceramic capacitiveloads .    The EMP8130 is available in miniatureSOT-23-5,uDFN-4, SC-70-5, SC-82-4, TSOT-23-5, SOT-23-3 andTDFN-6package.
Features
300mA guaranteed output current  75dB typical PSRR at 1kHz  260mV (VOUT=3.3V) typical dropout at 300mA  52μA typical quiescent current  Less than 1μA typical shutdown mode  Fast line and load transient response  1.7V to 5.5V input range  Auto-discharge during chip disable  0.8V to 4.0V output voltage range  Stable with small ceramic output capacitors  Fold-back over current protection  ±1% output voltage tolerance
Applications
 Wireless handsets  PCMCIA cards  DSP core power  Hand-held instruments  Battery-powered systems  Portable information appliances
全部回复(0)
