CJC6811为Cortex-M0+的MCU,内部(151 1247 6010 莫R )集成了USB,CODEC,SPI,I2S等,主要应用于USB-Type C数字音频耳机及USB-Type C数字音频转接头等产品,支持线控耳机,可实现通话,听歌等功能.
Audio CodecContain 1*ADC 2*DACs Sample rate:192k/176.4k/96k/88.2k/48k/44.1k (192k/176.4k are available only in USB audio class V2.0/High-speed mode)Support bit length:16/20/24/32bitDAC SNR 90.2dB DR 90.2dB
CJC6811A Cortex-M0+ based MCU,designedfor USB Headphone Appliances
CJC6811 is a Cortex-M0+ based MCU, designed for USB headphone appliances.It integrates one 32-bit RISC CPU with 16KB SRAM, USB, UART, IIC, audio codec,GPIO, TIMER, WDT, PWM, SPI, IIS, SPDIF, PDM, SARADC, PLL, LDO etc.CJC6811 can boot from external flash through SPI interface. After powered on, theprogram is read from external flash into internal SRAM for execution.The CJC6811 can run up to 48MHz, and it is designed with special care to minimizethe power consumption while allowing for the flexibility to reach for highperformance. It includes the clock gating for individual IP, and CJC6811 can befurther operated under different power-saving modes: Normal, Idle, Standby,Power-down, different mode have different clock and power strategy.
