全程教你做高频变压器.....
第一步
全部回复(357)
@zyd198089
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220595438.jpg');}"onmousewheel="returnimgzoom(this);">
@zyd198089
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220595489.jpg');}"onmousewheel="returnimgzoom(this);">
@zyd198089
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220595593.jpg');}"onmousewheel="returnimgzoom(this);">
@zyd198089
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220595656.jpg');}"onmousewheel="returnimgzoom(this);">
@zyd198089
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220595793.jpg');}"onmousewheel="returnimgzoom(this);">
@zyd198089
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220596271.jpg');}"onmousewheel="returnimgzoom(this);">
@zyd198089
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220596325.jpg');}"onmousewheel="returnimgzoom(this);">
@zyd198089
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220596388.jpg');}"onmousewheel="returnimgzoom(this);">
变压器测试频率80多K空负荷总电流50MA
@vilayson1
两种做法都不是很好,因为窗口占用率太低,我的做法和你差不多,也是用小线多股,但是我绕上去的时候绕线面是平的,我用0.6的线,绕第一层,整个层的厚度就只有0.6 绕法和你差不多,两束多股线并绕,绕完一层后出四条线头,分好头尾后把其中一个头和另一个尾接起来做中心抽头.但是因为我一层的厚度几乎是你的一层的1/4.所以我第2到第5层绕完次级后,还可以在最外层绕一层初级.形成夹心状,有利于减少漏感. 我在EC40加厚的变压器里,用这样的绕法,50KHZ工作频率,初级12V绕下了32股0.62的线,按7A/平方毫米算,可以过电流60A.磁材好可以输出700W功率.
这个帖子要顶啊,有经验的继续!
@YOU
@hbzjcjw
自己学会了再来卖弄好不好?按你的绕法,根本无法正常工作
我这样可以减少漏感.,再说我就是单边长一点也没什么关,我也做了很多这样的变压器从来也没有说单边有发热的现象,楼上的做法跟我的一样,我看过只是你没有注意观查,也是初次初次,要不然就次初次初,减少漏感.我到认为这样做的话单线合成发热大,楼上的做法我以前早就做了,功率大时发热现象,你理论想一想单根线通过大电流内阻大,,,,,所以我用了扁铜这种初次初做法,大电流时是一体的内阻小,再就扁铜可以很好的减少磁肤效应.....楼上的我早试了我很早就用了比这更多层的做法是次初次初次初,,还有就是初次次初.......你再好好看看吧
@vilayson1
我以前也是用多根线合成不好做但,窗口占用率很高,效果不错,EE30里高功率可以做到800W但我减下来了发热大,所以只做了500W就算了,听清楚磁是电脑上拆下来的频率做到80K左右....
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/69/421871220657585.jpg');}" onmousewheel="return imgzoom(this);">
@zyd198089
我以前也是用多根线合成不好做但,窗口占用率很高,效果不错,EE30里高功率可以做到800W但我减下来了发热大,所以只做了500W就算了,听清楚磁是电脑上拆下来的频率做到80K左右....[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/421871220657585.jpg');}"onmousewheel="returnimgzoom(this);">
此帖已被删除
