昨日在电源网发了个贴子求助,现在效率可以做到80%了,但是波形不好,现我把测试时的波形发上来,请大家再来帮忙看看如何解决.
http://bbs.dianyuan.com/topic/259301
推挽式电源请教
全部回复(13)
空载时MOS管控制极波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/70/2901511224233568.jpg');}" onmousewheel="return imgzoom(this);">
@不甘心
空载时MOS管控制极波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/70/2901511224233568.jpg');}"onmousewheel="returnimgzoom(this);">
满载时MOS管控制极波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/70/2901511224233638.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/70/2901511224233665.jpg');}" onmousewheel="return imgzoom(this);">
@不甘心
满载时MOS管控制极波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/70/2901511224233638.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/70/2901511224233665.jpg');}"onmousewheel="returnimgzoom(this);">
满载时次级整流二极管波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/70/2901511224233887.jpg');}" onmousewheel="return imgzoom(this);">
@不甘心
满载时次级整流二极管波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/70/2901511224233887.jpg');}"onmousewheel="returnimgzoom(this);">
怎么就没人帮忙一下呢?
@pads2005pcb
车载逆变电源,变压器,推挽输入12V,输出300V1A 开关频率40KHZ,效率不低于0.8占空比我不知道取多少,请你作决定,由于是急着开发的市场机,请大侠仔细帮我算好,万分感谢.如果能提供你的公式则更佳.
300W push-pull? except you use UC3846 current mode chips,if you use TL494/SG3525 you will be trapped at magnet bias, which often does not show up in experiments but blow up transistors several months after sold.
Recommend to build hard switched half-bridge topology and use UC3825/A as the main controller and IR2110 as the gate driver, with MOSFET 90N02, 90N03 or even 70N02 is enough.
set the UC3825 clock freq to 600Khz and so the PC40/PC44 transformer runs at its best matched freq 300Khz. A small FeAlSi toroid is recommended as the output inductor.
The transformer is very easy to build, EI28 core with only 2 windings--- PRI 1 : SEC 58( 5.5V -> (302/0.95=319V), assume maximum transistor and Cap ESR voltage down is 0.5V, in fact smaller as 0.3V or such)
maximum Duty to as large as possible in your experiment, My value is 95% largest.
@pads2005pcb
2901511224636919.doc
pads2005pcb你好!这是我所帮你算的推挽式开关变压器,供你参考,如果能用的话我再告诉你是如何计算的.我也是头一回做,权当是抛砖引玉吧!
初级请用铜带绕,开关管选用IRF3205就行了,输出为桥式整流.如有不妥,也请各位高手指正!
谢谢!
谢谢!
