· output: Ueff AC possible range 6-10 kV sinus or pulsed (pulsed with no higher peaks than 10kV)
· input: U DC possible range 5-12 V
· f possible range 50-100 kHz
· stationary Power output about 1-20 W
· electrical load : Capacity around 1-20pF
· power supply should be driven by batteries as well.
· desired Dimension of the power supply: 50mm x 50mm x 30mm
请问这是什么类型的电源?如要设计从何处着手?
全部回复(8)
