1:充电板
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/71/1278851227848785.gif');}" onmousewheel="return imgzoom(this);">
1278851227849039.sch
1278851227849067.pcb
500W/800W全部资料,已调试好,打包送上(续/已重新调试更改)
全部回复(24)
2:车载电源/EE42
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/71/1278851227849350.gif');}" onmousewheel="return imgzoom(this);">
1278851227849371.sch
1278851227849420.pcb
@huamg
3:在线式/UPS用PROTEL99SE可以自由更改.我浪费了很多时间和烧了很多管,也做了多种电路板,反复调试,也用了多种负载,本来要做正弦波的,考滤方波效率较高,所以用此方式.[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/72/1278851228213592.gif');}"onmousewheel="returnimgzoom(this);">1278851228213616.sch1278851228213655.pcb
你好,这个电路板图有问题吗!我已经做好了电路板准备安装了500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/71/2336441227854959.jpg');}" onmousewheel="return imgzoom(this);">
@huamg
还有这个电路图正确吗?500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/71/2336441227856422.jpg');}" onmousewheel="return imgzoom(this);">
@quandes
还有这个电路图正确吗?[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/71/2336441227856422.jpg');}"onmousewheel="returnimgzoom(this);">
完全正确.
充电板小更改,就是IC3843的2脚接负而少2个电阻而尔.如想降成本可将2110换成光耦和三极管形式.
@huamg
变压器输出组的同名端反了.
你以前的板子上多呢片358 这是怎么回事,好像原理图上都没有的啊,是不是接反馈变压器做过压保护的啊?500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/72/2398161228198477.gif');}" onmousewheel="return imgzoom(this);">
@matt353
你以前的板子上多呢片358 这是怎么回事,好像原理图上都没有的啊,是不是接反馈变压器做过压保护的啊?[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/72/2398161228198477.gif');}"onmousewheel="returnimgzoom(this);">
带358的是应急电源的,检测市电,在没电时自动打开应急电源.而这组是单纯的逆变的.是其中分解出来的.
下面这板是全面的在线电源,
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/72/1278851228204485.gif');}" onmousewheel="return imgzoom(this);">
线路图还没完全整理,很多都对不上号,我是业余的,因做PCB样板困难,所以周期较长.
下面这板是全面的在线电源,
@huamg
2:车载电源/EE42[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/71/1278851227849350.gif');}"onmousewheel="returnimgzoom(this);">1278851227849371.sch1278851227849420.pcb
3:在线式/UPS
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/72/1278851228213592.gif');}" onmousewheel="return imgzoom(this);">
@huamg
带358的是应急电源的,检测市电,在没电时自动打开应急电源.而这组是单纯的逆变的.是其中分解出来的.下面这板是全面的在线电源,[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/72/1278851228204485.gif');}"onmousewheel="returnimgzoom(this);">线路图还没完全整理,很多都对不上号,我是业余的,因做PCB样板困难,所以周期较长.
我也是业余的,还请多多指教了
@power on
板子画的挺漂亮!有几点想问一下输出的波型是纯方波吧?输出电压调节在哪里?高压回路的安全距离有些太近了,我测试了一下只有一毫米不到,要是距离再大一些安全性能更好一些 过几天依照此板图做一块玩玩感觉感觉性能怎么样
输出的波型是纯方波,如修改3524的占空比会变为人说的修正波了,高压整流傍边的可调电阻是调压(稳压)用的.
高压回路的安全距离是有些太近了,不过自己玩没问题,做认证是不能了,我大大小小都做过,我现在用的都有,还有一只用EE70做的大功率的.
充电变压器如业余自已绕,最好用闭环EC磁芯,气息用一张名片纸三端都一层即可,如用EI磁芯要用两层名片纸,否则会炸机的,EI磁芯效率会低一点,用EC充满电后基本上是不耗电的.还有,充电输出电感可用线短接.
逆变电路在启动后的空载电流是50-70MA,如电流超100MA就要注意了,1/升压变压器,2/H桥的2110不对称(电子调市场要小心),3/高压滤波电容质量.
电源滤波电容一定要用50V的,我曾用过25V的发热.
试机时断开后级先试前级,保险丝用一12V/50W灯串接,试好机后换1平方的铜线焊接好就OK了.
祝你成功!!!
祝你成功!!!
@huamg
输出的波型是纯方波,如修改3524的占空比会变为人说的修正波了,高压整流傍边的可调电阻是调压(稳压)用的.高压回路的安全距离是有些太近了,不过自己玩没问题,做认证是不能了,我大大小小都做过,我现在用的都有,还有一只用EE70做的大功率的.充电变压器如业余自已绕,最好用闭环EC磁芯,气息用一张名片纸三端都一层即可,如用EI磁芯要用两层名片纸,否则会炸机的,EI磁芯效率会低一点,用EC充满电后基本上是不耗电的.还有,充电输出电感可用线短接.逆变电路在启动后的空载电流是50-70MA,如电流超100MA就要注意了,1/升压变压器,2/H桥的2110不对称(电子调市场要小心),3/高压滤波电容质量.电源滤波电容一定要用50V的,我曾用过25V的发热.试机时断开后级先试前级,保险丝用一12V/50W灯串接,试好机后换1平方的铜线焊接好就OK了.祝你成功!!!
充电的变压器初步设想用电视机上拆下的EC40 那个磁隙已经开好了的应该能用吧
在电视上用的时候一般是40KHZ UC3843工作频率也在40左右我想应该差不多 郁闷前几天邮购了一些电子元件 我要的是UC3843和3842 结果发来的全是UC3842 代用不知道效果会怎么样?他们的保护电压好像是不太一样管它哪先试一下再说!嘿嘿实践才是硬道理嘛!
H桥上的740 我不想用,手头上的740都是拆机的质量不是太好,准备用IRFP450 不知道会不会出现你说的电感性负载是关不思的情况
总体构思:EE55 初级2+2 6平方铜带 次级45 0.85漆包线*2
绕制顺序:次级15 初级2+2次 次级15 初级2+2 次级15
呵呵给个意见!!!
呵呵给个意见!!!
@power on
充电的变压器初步设想用电视机上拆下的EC40那个磁隙已经开好了的应该能用吧在电视上用的时候一般是40KHZ UC3843工作频率也在40左右我想应该差不多 郁闷前几天邮购了一些电子元件我要的是UC3843和3842结果发来的全是UC3842代用不知道效果会怎么样?他们的保护电压好像是不太一样管它哪先试一下再说!嘿嘿实践才是硬道理嘛!H桥上的740我不想用,手头上的740都是拆机的质量不是太好,准备用IRFP450不知道会不会出现你说的电感性负载是关不思的情况总体构思:EE55初级2+26平方铜带 次级45 0.85漆包线*2绕制顺序:次级15初级2+2次次级15初级2+2次级15呵呵给个意见!!!
你好,3842的起始供电电压16V不好处理,3843的供电在9V-28V工作都有很稳定,见议用3843较好.电视机的变压器很好用.H桥的事情没问题的,原来的问题出在继电器,有一边不动.
变压器的绕法不用这样麻烦,先绕2+2,后再绕高压组.不过与高压组的绝缘要处理好,高频电的感应...造成你头痛
@huamg
你好,3842的起始供电电压16V不好处理,3843的供电在9V-28V工作都有很稳定,见议用3843较好.电视机的变压器很好用.H桥的事情没问题的,原来的问题出在继电器,有一边不动.变压器的绕法不用这样麻烦,先绕2+2,后再绕高压组.不过与高压组的绝缘要处理好,高频电的感应...造成你头痛
这几天正在制作中 图纸是照 你第三帖那个在线式UPS 作的 想问一下那个U6 LM339电压比较器是控制自动充电的,调试RW2 电瓶电压是不是应该在10.8伏时自动充电开始工作? 然后是充电到14.4伏时输出信号经过光偶关闭UC3843 ?换句话说就是;应该带满电自停的吧!!我对LM339这个四电压比较器不是太熟悉别见笑!
另外就是这个过载保护真的不太容易理解!!!!调整R42的阻值就可以改变保护器的工作阀值??
以前作过几个逆变器都在变压器初级加了RC吸收回路,不加的话波型不太好.为了保险起见我也在这个电路里面加上了吸收回路和图腾柱电路,我的变压器工作在50K 个人感觉3525直接推8个场管在这个工作频率好像是有点力不从心.
@huamg
你好,这个我想做一下,请问做出来效果怎么样啊?能不能发个实物上来看一下.
@power on
这几天正在制作中图纸是照你第三帖那个在线式UPS作的 想问一下那个U6LM339电压比较器是控制自动充电的,调试RW2电瓶电压是不是应该在10.8伏时自动充电开始工作? 然后是充电到14.4伏时输出信号经过光偶关闭UC3843?换句话说就是;应该带满电自停的吧!!我对LM339这个四电压比较器不是太熟悉别见笑!另外就是这个过载保护真的不太容易理解!!!!调整R42的阻值就可以改变保护器的工作阀值??以前作过几个逆变器都在变压器初级加了RC吸收回路,不加的话波型不太好.为了保险起见我也在这个电路里面加上了吸收回路和图腾柱电路,我的变压器工作在50K个人感觉3525直接推8个场管在这个工作频率好像是有点力不从心.
这个我也看不明白,无论是原理图还是PCB上看都觉得不靠谱。原理图上10K和100K并联接地;PCB上10K和100K分别接FUSE两端子地。难道保险险丝烧断后还在工作?只是接地不同?电平才变化?U5的5脚电平又是从哪来的(只有两个接地电阻啊?)
