• 2
九齐单片机NY8A053D\NY8A053E\NY8A054D\NY8A054E方案开发、技术支持
NY8A053和NY8A054系列基本差不多,当然是越往后编号的产品越新,产品性能更好,支持更多,内存更大
现在市面主流还是NY8A053E和NY8A054E这两个用的多
型号:NY8A053B
封装: SOP-8 SOP-14 SOP-16
多数应用于小风扇,玩具,简易遥控,喇叭,有硬件PWM,性价比超高
NY8A053B例程有汇编版本,有C语言版本,可以联系我索取
NY8A053B例程:Checksum
NY8A053B例程:External lnterrupt_Level
NY8A053B例程:Change lnterrupt
NY8A053B例程:GPIO
NY8A053B例程:GPIO_Direct Input
NY8A053B例程:GPIO_LED Pattern
NY8A053B例程:GPIO_Matrix Input
NY8A053B例程:GPIO_Running LED
NY8A053B例程:GPIO_Running LED_Table
NY8A053B例程:Mix AssemblyPWM Output
NY8A053B例程:Rolling Code_CustomRolling Code_Preset
NY8A053B例程:Sleep_Wakeup
NY8A053B例程:Special IO Function
NY8A053B例程:Timer Interrupt_WDT Interrupt
NY8A053BPDF资料,请点击下方链接下载
NY8A053B_v1.5_SYKJ_SYKJ.pdf
型号:NY8A053D
NY8A053D是NY8A053B的升级产品
NY8A053D例程有汇编版本,有C语言版本,可以联系我索取
NY8A053D例程:Checksum
NY8A053D例程:External lnterrupt_Level
NY8A053D例程:Change lnterrupt
NY8A053D例程:GPIO
NY8A053D例程:GPIO_Direct Input
NY8A053D例程:GPIO_LED Pattern
NY8A053D例程:GPIO_Matrix Input
NY8A053D例程:GPIO_Running LED
NY8A053D例程:GPIO_Running LED_Table
NY8A053D例程:Mix AssemblyPWM Output
NY8A053D例程:Rolling Code_CustomRolling Code_Preset
NY8A053D例程:Sleep_Wakeup
NY8A053D例程:Special IO Function
NY8A053D例程:Timer Interrupt_WDT Interrupt
NY8A053D_v1.5_SC_SYKJ_SYKJ.pdf
型号:NY8A053E
NY8A053E是NY8A053D的升级产品,目前市场用量大,功能多了LVD
NY8A053E例程有汇编版本,有C语言版本,可以联系我索取
NY8A053E例程:Checksum
NY8A053E例程:Comparator_P2P Mode
NY8A053E例程:Comparator_P2V Mode
NY8A053E例程:External lnterrupt_Level Change lInterrupt
NY8A053E例程:GPIO
NY8A053E例程:GPIO_Direct lnput
NY8A053E例程:GPIO_LED Pattern
NY8A053E例程:GPIO_Matrix Input
NY8A053E例程:GPIO_Running LED
NY8A053E例程:GPIO_Running LED_Table
NY8A053E例程:LVD
NY8A053E例程:Mix Assembly
NY8A053E例程:PWM Output
NY8A053E例程:Rolling Code_Custom
NY8A053E例程:Rolling Code_Preset
NY8A053E例程:Sleep_Wakeupspecial lO Function
NY8A053E例程:Timer Interrupt_WDT Interrupt
NY8A053E_v1.1_SC_SYKJ_SYKJ.pdf
型号:NY8A054A
NY8A054A是NY8A053系列的升级产品,目前市场用量大,功能多了LVD,多了一路硬件PWM
NY8A054A例程有汇编版本,有C语言版本,可以联系我索取
NY8A054A例程:Checksum
NY8A054A例程:Comparator_P2P Mode
NY8A054A例程:Comparator_P2V Mode
NY8A054A例程:External lnterrupt_Level Change lInterrupt
NY8A054A例程:GPIO
NY8A054A例程:GPIO_Direct lnput
NY8A054A例程:GPIO_LED Pattern
NY8A054A例程:GPIO_Matrix Input
NY8A054A例程:GPIO_Running LED
NY8A054A例程:GPIO_Running LED_Table
NY8A054A例程:LVD
NY8A054A例程:Mix Assembly
NY8A054A例程:PWM Output
NY8A054A例程:Rolling Code_Custom
NY8A054A例程:Rolling Code_Preset
NY8A054A例程:Sleep_Wakeupspecial lO Function
NY8A054A例程:Timer Interrupt_WDT Interrupt
NY8A054A_v1.5_SYKJ_SYKJ.pdf
型号:NY8A054D
NY8A054D是NY8A054A的升级产品,目前市场用量大,功能多了LVD,多了一路硬件PWM
NY8A054D例程有汇编版本,有C语言版本,可以联系我索取
NY8A054D例程:Checksum
NY8A054D例程:Comparator_P2P Mode
NY8A054D例程:Comparator_P2V Mode
NY8A054D例程:External lnterrupt_Level Change lInterrupt
NY8A054D例程:GPIO
NY8A054D例程:GPIO_Direct lnput
NY8A054D例程:GPIO_LED Pattern
NY8A054D例程:GPIO_Matrix Input
NY8A054D例程:GPIO_Running LED
NY8A054D例程:GPIO_Running LED_Table
NY8A054D例程:LVD
NY8A054D例程:Mix Assembly
NY8A054D例程:PWM Output
NY8A054D例程:Rolling Code_Custom
NY8A054D例程:Rolling Code_Preset
NY8A054D例程:Sleep_Wakeupspecial lO Function
NY8A054D例程:Timer Interrupt_WDT Interrupt
NY8A054E_v1.2_SC_SYKJ_SYKJ.pdf
型号:NY8A054E
NY8A054E是NY8A054D的升级产品,目前市场用量大,功能多了LVD,多了一路硬件PWM
NY8A054E例程有汇编版本,有C语言版本,可以联系我索取
NY8A054E例程:Checksum
NY8A054E例程:Comparator_P2P Mode
NY8A054E例程:Comparator_P2V Mode
NY8A054E例程:External lnterrupt_Level Change lInterrupt
NY8A054E例程:GPIO
NY8A054E例程:GPIO_Direct lnput
NY8A054E例程:GPIO_LED Pattern
NY8A054E例程:GPIO_Matrix Input
NY8A054E例程:GPIO_Running LED
NY8A054E例程:GPIO_Running LED_Table
NY8A054E例程:LVD
NY8A054E例程:Mix Assembly
NY8A054E例程:PWM Output
NY8A054E例程:Rolling Code_Custom
NY8A054E例程:Rolling Code_Preset
NY8A054E例程:Sleep_Wakeupspecial lO Function
NY8A054E例程:Timer Interrupt_WDT Interrupt
如果您还没有接触这个品牌的单片机,又想学习,建议您准备两个硬件,一个是
1:NY8-OTP_Writer 烧录器 (大概400左右)
2:NY8_ADC/COM_COB (大概450左右)
深圳市双宜科技有限公司成立于2012年,我们提供一站式产品服务,方案设计,PCB设计,元器件配套。
有任何问题欢迎联系我们
电话:13823527686(微信同号)
联系人:倪先生
联系我时,请注明是电源网看到联系方式
全部回复(2)
冲鸭,可达鸭方案配套
