光眼问题.谢谢了!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/27/1112196141.gif');}" onmousewheel="return imgzoom(this);">
全部回复(9)
gogo991
我自己顶一下~~!~!
gogo991
@gogo991
我自己顶一下~~!~!
恳请回复!
gogo991
@gogo991
恳请回复!
是我画的不好么?还是有不对的地方呢!?
小学生
@gogo991
是我画的不好么?还是有不对的地方呢!?
HI!Boy, i believe u rush into a completely wrong place.
the bbs is just for power.
optical-eye is preserved patent of Logictech.
the producer said it's used high speed CCD tech. inside.
but i belive it incorporated  with coherent optical tech.
u choice a good target,but i can't give u more comment,sorry.
ghost
@小学生
HI!Boy,ibelieveurushintoacompletelywrongplace.thebbsisjustforpower.optical-eyeispreservedpatentofLogictech.theproducersaidit'susedhighspeedCCDtech.inside.butibeliveitincorporated  withcoherentopticaltech.uchoiceagoodtarget,butican'tgiveumorecomment,sorry.
hi !young boy,please translate these sentences into chinese,because none understand  what you said ,there was 5 errors in your sentences.can't you find them?by the way ,what do you do? a student? a teacher?
gogo991
@ghost
hi!youngboy,pleasetranslatethesesentencesintochinese,becausenoneunderstand  whatyousaid,therewas5errorsinyoursentences.can'tyoufindthem?bytheway,whatdoyoudo?astudent?ateacher?
我不管他错的哪几个地方.
这是电源论谈.不要讨论英语问题OK?
晕死了.顶!~
总会有人回答我的
ghost
有性格我欣赏!虽然你的图不对可大概意思我明白.要改的地方你可从描述中查觉.R4为发光二极管D2限流电阻,D1为光敏电阻信号经T1放大(R5为D1偏置电阻,R1R2为T1偏置电阻使放大电路能正常工作)后由集电极输出经NO到COIN遮光时能改变输出状态,而T2R3提供一个低电位经集电极输出到NC端通过拨位开关的控制可使电路工作在手动或遮光控制方示,不知分析的和作者本意有何差别?
gogo991
@ghost
帅哥.
你的话上半部分小弟基本理解.
这个电路图主要是用于计数的.
当NC与中间的点短路时.我们视为"常连"COIN与地线视为短路处理.当有一物体在二只发光二极管中间穿过时.计数器计一数
当NO与中间点短路时.我们视为"常开"COIN与地线视为开短处理.当有一物体在二只发光二极管中间穿过时.计数器计一数
NC与NO只是视二种机器型号而用到不同的常连与常开.
再次想问一下.R5为何种偏置电阻?
ghost
@gogo991
帅哥.你的话上半部分小弟基本理解.这个电路图主要是用于计数的.当NC与中间的点短路时.我们视为"常连"COIN与地线视为短路处理.当有一物体在二只发光二极管中间穿过时.计数器计一数当NO与中间点短路时.我们视为"常开"COIN与地线视为开短处理.当有一物体在二只发光二极管中间穿过时.计数器计一数NC与NO只是视二种机器型号而用到不同的常连与常开.再次想问一下.R5为何种偏置电阻?
这就对了吗,你想想没有R5,D1怎能输出高低电平?
