• 19
TN2 LNK3206GQ
4.5 W Non-Isolated Buck Power Supply
本设计用于提供非隔离额定输出电压为15 V,负载为300 mA,输入电压范围为60VDC至550 VDC用于汽车应用,非常值得尝试。
主电路
The schematic in Figure 2 shows a buck converter using LNK3206GQ. The circuit provides a non-isolated 15 V, 300 mA continuous output. In this design, automotive battery will be the intended input source of the buck circuit. To simulate battery stiff voltage source, bulk capacitors was added in the test setup during the test as shown in Figure 3. The LinkSwitch™-TN2 family of ICs for automotive power supplies provide significant reduction in component count compared to traditional discrete solutions. Regulation is achieved using a low cost resistor divider feedback network. The switching frequency jitter feature of the LinkSwitch-TN2 family and the 66 kHz switching frequency of operation helps reduce EMI. Each device incorporates a 750 V power MOSFET, oscillator, On/Off control, a high-voltage switched current source for self-biasing, frequency jittering, fast (cycle-by-cycle) current limit, hysteretic thermal shutdown, and output and overvoltage protection circuitry onto a monolithic IC. LinkSwitch-TN2 ICs consume very little current in standby resulting in power supply designs that meet <50 mW no-load input at 400 VDC input. A full suite of protection features enable safe and reliable power supplies protecting the device and the system against input and output overvoltage faults, device over-temperature faults, lost regulation, and power supply output overload or short-circuit faults. Due to automotive application, all component selected are AEC compliant.
PCB设计也很简单,有兴趣可进一步到PI官网了解。
全部回复(19)
输入电压范围为60VDC至550 VDC,负载电流可达300mA,非常适合用于汽车应用的场合。
汽车应用的场合有很多未来
cmdz002
亮点是LNK3206GQ符合AEC-Q100标准,应用于HVAC/恒温控制系统, 电池管理系统, 牵引逆变器,DC/DC母线变换器等场合。
新月GG
@cmdz002
亮点是LNK3206GQ符合AEC-Q100标准,应用于HVAC/恒温控制系统,电池管理系统,牵引逆变器,DC/DC母线变换器等场合。
控制芯片集成了MOS管、控制芯片,极大的节省了电源的体积。
沈夜
在该设计中,如何实现对LinkSwitch-TN2 IC进行反馈调节以实现稳定的输出电压?
Marcia
这款汽车开关IC在减小尺寸的同时,还提高了汽车子系统的可靠性和稳定性
阿飞啊
非常值得尝试
k6666
@cmdz002
能提供低成本且有效的保护,同时还可大幅降低运营及产品支持成本。
k6666
@新月GG
适用元件数极少的降压转换器,提供集成900 V初级MOSFET的全套离线式开关电源IC,这些产品不仅能提供低成本且有效的保护
dy-nmLUWFNr
有没有具体的能量传输曲线来描述这个变化过程
denyuiwen
无需使用光电 隔离器 ,支持降压式,降压-升压式和反激式变换器拓扑结构
dy-StTIVH1p
这个设计主要的应用场景是什么
dy-nmLUWFNr
有没有对应的中文介绍说明
spowergg
@沈夜
在该设计中,如何实现对LinkSwitch-TN2IC进行反馈调节以实现稳定的输出电压?
可依据不同应用,简单的借由外部两颗回授电阻来调整所需的输出电压
飞翔2004
@dy-StTIVH1p
这个设计主要的应用场景是什么
AC输入过零点检测可用于控制主功率器件的接入和关断切换,以降低工作压力并有助于延长预期寿命和提高可靠性。
沈夜
为什么选择LNK3206GQ作为buck转换器的IC?有没有其他替代品?
tanb006
这效率太低,如果价格几毛钱,还愿意尝试一下。
楼主这NB,发的纯纯的英文的,看不懂,给翻译下中文?
k6666
@追魂幡℃
汽车应用的场合有很多未来
电源的设计包括计算实现最大输出功率所需的变压器初级电感,提供给负载的功率与变压器初级电感及峰值初级电流的平方成正比
