NS LM3421-3高压LED驱动方案
NS公司的LM3421/LM3423是多用途高压LED驱动,可以配置成降压,升压,降压-升压(反激)或SEPIC拓扑,输入电压从4.5V到高达75V,可调开关频率高达2MHz,具有快速(50kHz) PWM调光,关断电流小于1uA,可用在LED驱动器和多种恒流模式稳压器以及热电冷却驱动器.本文介绍了LM3421/LM3423的住要特性,方框图以及多种应用电路图,升压评估板主要特性和电路图和材料清单(BOM).
LM3421/ LM3423:N-ChannEL Controllers for Constant Current LED Drivers
The LM3421/LM3423 devices are versatile high voltage LED driver controllers. With the capability to be configured in a Buck, Boost, Buck-Boost (Flyback), or SEPIC topology, and an input operating voltage rating of 75V, these controllers are ideal for illuminating LEDs in a very diverse, large family of applications.
Adjustable high-side current sense with a typical sense voltage of 100mV allows for tight regulation of the LED current with the highest efficiency possible. Output LED current regulation is based on peak current-mode control with predictive Off-Time Control. This method of control eases the design of loop compensation while providing inherent input voltage feed-forward compensation.
The LM3421/LM3423 include a high-voltage startup regulator that operates over a wide input range of 4.5V to 75V. The internal PWM controller is designed for adjustable switching frequencies of up to 2.0MHz, thus enabling compact solutions.
Additional features include: “zero” current shutdown, precision reference, logic compatible DIM input suitable for fast PWM dimming, cycle-by-cycle current limit, and thermal
shutdown.
The LM3423 also includes an LED output status flag, a fault flag, a programmable fault timer, and a logic input to select the polarity of the dimming output driver.
LM3421-3主要特性:
■VIN range from 4.5V to 75V
■2% Internal reference voltage (1.235V)
■Current sense voltage adjustable from 20mV
■High-side current sensing
■2Ω MOSFET gate driver
■Dimming MOSFET gate driver
■Input under-voltage protection
■Over-voltage protection
■Low shutdown current, IQ < 1μA
■Fast (50kHz) PWM dimming
■Cycle-by-cycle current limit
■Programmable switching frequency
■LED output status flag (LM3423 only)
■Fault timer pin (LM3423 only)
■TSSOP EP 16-lead package (LM3421)
■TSSOP EP 20-lead package (LM3423)
LM3421-3应用:
■LED Drivers
■Constant-Current Buck-Boost Regulator
■Constant-Current Boost Regulator
■Constant-Current Flyback Regulator
■Constant-Current SEPIC Regulator
■Thermo-Electric Cooler (Peltier) Driver
各位如有需要详细资料以及相关技术咨询,请联系国半代理商中国电子器材总公司中电华星电子公司李斌(13902936345) 0755-82531600,E-MAIL:robin.li@ce-power.com
全部回复(3)
现在还在做吗?我样片做的板子不起振,或者频率只有3k-9K
@fengredsky
有兴趣也可以联系我~~我这里已经做出了成熟的方案~~~小罗13266883219  QQ:1061076430
robin2312
@fengredsky
方便的话留个联系方式,我好和你具体进行沟通。谢谢!
