【 DigiKey DIY原创大赛】基于树莓派5B和CSI摄像头的手势控制---项目实操
系统框图
第一部分:
系统选择
选择树莓派5的官方64位版本
配置虚拟环境
使用virtualenv或者venv
python3 -m venv --system-site-packages env1
安装OPENCV库
pip3 install opencv-python==4.7.0.72
pip3 install opencv-contrib-python==4.7.0.72
安装opencv要注意与python版本相对应。目前树莓派5官方64位系统自带的是
python 3.11版本。
piwheels - opencv-python参考这个网站查看二者对应版本
安装 mediapipe库
pip3 install mediapipe
编写简单测试代码
from picamera2 import Picamera2
import cv2
import time
import mediapipe as mp
import numpy as np
if __name__ == "__main__":
    camera = Picamera2()
    camera.start()
    mpHands = mp.solutions.hands
    hands = mpHands.Hands()
    mpDraw = mp.solutions.drawing_utils
    while True:
       camera.resolution =(640,480)
       im = camera.capture_array("main")
       image_height, image_width, _ =np.shape(im)
       #raw_capture = PiRGBArray(camera,size=(640,480))
       #time.sleep(2)
       #camera.capture(raw_capture, format='bgr')
       #image = raw_capture.array
       imgRGB= cv2.cvtColor(im, cv2.COLOR_BGR2RGB)
       results = hands.process(imgRGB)
       if results.multi_hand_landmarks:
           for hand in results.multi_hand_landmarks:
                print("\r%.2f %.2f %.2f %.2f %.2f %.2f "%(hand.landmark[0].z,hand.landmark[4].z,hand.landmark[8].z,hand.landmark[12].z,hand.landmark[16].z,hand.landmark[20].z),end="")
                #mpDraw.draw_landmarks(im,hand,mpHands.HAND_CONNECTIONS)
                for i in range(21):
                    pos_x = hand.landmark[i].x*image_width
                    pos_y = hand.landmark[i].y*image_height
                    cv2.circle(im, (int(pos_x),int(pos_y)), 3, (0,255,255),-1)
       cv2.imshow("hands",im)
       key =  cv2.waitKey(1) & 0xFF
       if key ==  ord('q'):
            break
    camera.release()
第二部分:
手势识别现象:
第三部分:
以下视频演示:
手势识别
全部回复(0)
