提供各种电子版图书及外文数据库(EI,INSPEC,IEEE)检索.
提供各种电子版图书及外文数据库检索.可以提供各种电子版图书及外文数据库全文检索.包括EI,INSPEC,IEEE等...
提供的图书及论文格式全部为PDF通用格式.可以永久使用.
每张光盘容量在690M以上.
可以为你提供外文数据库检索权限,你可以自己查找需要的论文.
免费为你查找你有难以查到的论文.请提供检索的数据库及篇名.....
联系方式
QQ122593038
liubarry@tom.com
电源类图书目录,三张光盘,200余种书..
1112955336.txt
收音机,音响,无线电,电子制作,电子仪器,家电等图书目录.六张光盘..
1112955417.txt
购全套光盘送期刊网及IEEE检索权限..
全部回复(17)
bazooka
您好,帮忙查以下的文章,谢谢您了
Self excited half-bridge series resonant parallel loaded fluorescent lamp electronic ballasts
High-power-factor electronic ballast for metal halide lamps with hot restarting
PWM control of electronic ballast for high-pressure Na lamps in comparison to fluorescent lamps Introduction to quasi-optimum control
High-power-factor constant-frequency electronic ballast for metal halide lamps
Low-Cost High Power-Density Electronic Ballast for Automotive HID Lamp
Electronic ballasts for metal halide lamps
Analysis and design of a HID lamp ballast with sinusoidal waveform superposed with 3rd harmonic
Solution to the warm up problems on HID sodium lamp ballasts controlled by resonant current
Igniting high-pressure lamps with electronic ballasts
Study of hid lamps with reduced acoustic frequency spectra
万分感谢!!!
sy2008
论文:Self excited half-bridge series resonant parallel loaded fluorescent lamp electronic ballasts
1113390761.pdf
High-power-factor electronic ballast for metal halide lamps with hot restarting 1113392384.pdf
PWM control of electronic ballast for high-pressure Na lamps in comparison to fluorescent lamps Introduction to quasi-optimum control 1113392607.pdf
1113394779.pdf
998lllll
网友xaudream请求提供IEEE的文章:
Kutkut, N.H., D.M. Divan, R.W. Gascoigne. An improved full bridge zero-voltage switching PWM converter using a two inductor rectifier. IEEE-IAS Conf. Rec. Oct 2-8, 1993. Part II. pp. 1065-1072. IEEE Trans. on Ind. Appl. January/February 1995. Vol. 31. No. 1. pp. 119-126.
sy2008
@998lllll
网友xaudream请求提供IEEE的文章:Kutkut,N.H.,D.M.Divan,R.W.Gascoigne.Animprovedfullbridgezero-voltageswitchingPWMconverterusingatwoinductorrectifier.IEEE-IASConf.Rec.Oct2-8,1993.PartII.pp.1065-1072.IEEETrans.onInd.Appl.January/February1995.Vol.31.No.1.pp.119-126.
版主好热心呀,支持一下.1113393973.pdf
998lllll
@sy2008
谢谢,给你加分。
sy2008
@998lllll
谢谢,给你加分。
上上...
sy2008
@sy2008
上上...
顶...
gaofr317
@sy2008
这个文件下载打不开,我上一个,希望可以用1115197841.pdf
gaofr317
@gaofr317
IEEETrans.onInd.Appl.January/February1995.Vol.31.No.1.pp.119-126.这个文件下载打不开,我上一个,希望可以用1115197841.pdf
Alonso, J.M.; Calleja, A.J.; Lopez, E.; Cardesin, J.; Garcia, J.;
Power Electronics Specialist Conference, 2003. PESC '03. 2003 IEEE 34th Annual
Volume 3,  15-19 June 2003 Page(s):971 - 976 vol.31115198362.pdf
998lllll
ding
sy2008
@998lllll
ding
UP
sy2008
@sy2008
UP
本人需要一个12V 4A的稳压电源,用来给车用收音机供电,如果哪位朋友能够提供,可以用电子书光盘交换,或者购买...
有意者请联系.
sy2008
@sy2008
本人需要一个12V4A的稳压电源,用来给车用收音机供电,如果哪位朋友能够提供,可以用电子书光盘交换,或者购买...有意者请联系.
你需要IEEE的检索权限吗?
leo8864
请问能否提供IEEE的检索权限,谢谢!
sy2008
@leo8864
请问能否提供IEEE的检索权限,谢谢!
需要IEEE的检索权限联系我...
zpower
@sy2008
需要IEEE的检索权限联系我...
我需要IEEE文献的检索权限,请联系我。万分感谢!
@zpower
我也需求,请上传.THANKS!
