请求帮助 倍流整流 的IEEE文章
请帮忙找一下这篇文章 Kutkut, N.H., D.M. Divan, R.W. Gascoigne. An improved full bridge zero-voltage switching PWM converter using a two inductor rectifier. IEEE-IAS Conf. Rec. Oct 2-8, 1993. Part II. pp. 1065-1072. IEEE Trans. on Ind. Appl. January/February 1995. Vol. 31. No. 1. pp. 119-126.
