请推荐DC/DC降压芯片
本人正设计一款12转05输出的200MA的电源,由于要求封装小,现请朋友们推荐一款降压IC,要求输出外接电容小,就可达到很低的纹波,尽量IC里已内置MOS管,这样体积就小,(33063输出要很大的电容,所以不选它了)IC温度一定要达到-40~85度,主要是准军品的产品.
全部回复(18)
我公司的AP1509应该适合你用吧,看看吧,有需要可以给我电话:0755-83679248-329 http://www.anachip.com.tw
AP1509.pdf
AP1509.pdf
DC-DC降压: LM2575T-3.3, 5.0, 12, 15, ADJ. LM2575S-3.3, 5.0, 12, 15, ADJ
LM2576T-3.3, 5.0, 12, 15, ADJ. LM2576S-3.3, 5.0, 12, 15, ADJ
LM2576HVT-3.3, 5.0, 12, 15, ADJ. LM2576HVS-3.3, 5.0, 12, 15, ADJ
LM2596T-3.3, 5.0, 12, 15, ADJ. LM2596S-3.3, 5.0, 12, 15, ADJ我这边有代理美国HN公司无刷直流电机控制芯片MC33035,另DC/DC LM2576 LM2596 降压芯片,可提供3A固定输出电流输入电压可承受40-60V电压,还提供DC/DC芯片,3842 3843 3844 3845 431 494 34063 等电源器件
华东地区如有需要请联系13817675859谢先生
The ACT4060 is a current-mode step-down
DC-DC converter that generates up to 2A output
current at 410kHz switching frequency. The
device utilizes Active-Semi’s proprietary
ISOBCD20 process for operation with input
voltage up to 20V.
Consuming only 8µA in shutdown mode, the
ACT4060 is highly efficient with peak efficiency
at 95% when in operation. Protection features
include cycle-by-cycle current limit, thermal
shutdown, and frequency fold back at short
circuit.
http://www.micro-bridge.com/ACT4060.asp
Micro Bridge Technology Co.,Ltd.
Tel: 86-755-83991588
voltage up to 20V.
circuit.
