哪位能帮忙下载一篇IEEE的论文,多谢了
Article Information
Influences of magnetic inductance, leakage inductance and saturable inductance on an active clamp forward converter
Jian Tian; Reimann, T.; Scherf, M.; Li, D.; Deboy, G.; Maerz, M.; Petzoldt, J.
Power Electronics and Applications, 2007 European Conference on
Volume , Issue , 2-5 Sept. 2007 Page(s):1 - 8
Digital Object Identifier   10.1109/EPE.2007.4417262
Summary:In this paper, the influences of the magnetic inductance, leakage inductance and saturable inductor on the behaviour of the active clamp forward are analyzed, and their mathematic solutions are given. Based on the analysis, the other topology variant is proposed, which can be used to reduce the oscillation across the freewheeling switch and improve the ZVS condition of the auxiliary switch in primary side. This leads to improve the EMI behaviour and efficiency because the low voltage rectifier switches could be used. To verify these analyse, some experimental results are presented.
MAIL: woyangsizhong@sina.com
不胜感激
全部回复(3)
小雨
现在IEEE是不好找,很多帐号都是作废的
估计在学校的可以有资源,我有时候就厚着脸皮让一些还在学校的同学帮忙
帮你顶
1445891237344624.pdf
刚好有同学在上大,让她帮找找,看是么?
胡庄主
@电源网-娜娜姐
1445891237344624.pdf刚好有同学在上大,让她帮找找,看是么?
多谢2位,同时发来了我要的文章,感激不尽.
