请教:UL插座用什么标准,面板,安装,插孔位等尺寸要求安什么标准
UL插座用什么标准,面板,安装,插孔位等尺寸要求按什么标准,谢谢!
全部回复(6)
@richardweng
用UL817
UL817 是Cord Sets and Power-Supply
Cords standard,非插座standard.求救! 3219201237873605.pdf
@阿牛888
UL817是CordSetsandPower-SupplyCordsstandard,非插座standard.求救!3219201237873605.pdf
不好意思,请自己在下列标准中查找有没有合适的标准可以用
美国插座标准(ANSI socket standards)
ANSI | BS | DIN | EN | GB | IEC | JIS | NF | DIC
编号 中文名称 英文名称
ANSI C12.7-2005 电度表插座要求 Requirements for Watthour Meter Sockets
ANSI C136.10-2006 道路和地区照明设备.锁定式光控装置和配套的插座.物理和电气互换性及测试 Roadway and Area Lighting Equipment - Locking-type Photocontrol Devices and Mating Receptacles - Physical and Electrical Interchangeability and Testing
ANSI C136.4-2003 道路照明设备.系列插座和系列插座插孔 Roadway Lighting Equipment - Series Sockets and Series-Socket Receptacles
ANSI PH3.107-1983 摄影(照相机).快门线顶尖和插座.尺寸 Photography (Cameras) - Shutter Cable Release and Socket - Dimensions
ANSI/AMCA 99-2412-2003 离心式风扇用叶轮直径和插座区 Impeller Diameters and Outlet Areas for Centrifugal Fans
ANSI/EIA 364-87-1996 电气连接件,接触件和插座的毫微秒事件检测 Nanosecond Event Detection for Electrical Connectors, Contacts and Sockets
ANSI/EIA 540AA00-1991 电子设备用无引线A、B、D型片载体用片载插座的空白详细规范 Chip Carrier Sockets for Leadless type A,B,D Chip Carriers for use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA 540AB00-1991 电子设备用塑料方形扁平组件的片载插座的空白详细规范 Chip Carrier Sockets for Plastic Quad Flat Packages for Use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA 540AC00-1991 电子设备用"J"型引线塑料片载体(PCC)组件的片载插座的空白详细规范 Chip Carrier Sockets for Plastic Chip Carrier (PCC) Packages with J Type Leads for Use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA 540AD00-1991 电子设备用针式格子排列插座的适配器载体方形扁平外壳的详细规范 Adapter-Carrier Quad Flat Pack to Pin Grid Array Sockets for Use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA 540B0AA-2001 用于电子设备有1.27mm间距的BGA插座的详细规范 Detail Specification for Production Ball Grid Array (BGA) Sockets with 1.27 mm (0.050 in) Spacing for Use in Electronic Equipment
ANSI/EIA 540DB00-1993 退耦合电容器双排标准组合插件插座的空白详细规范 Blank Detail Specification for Decoupling Capacitor Dual-in-Line Package Sockets
ANSI/EIA 540F000-1991 电子设备用多组组合插座的分规范 Multi-Package Module Sockets for Use in Electronic Equipment, Sectional Specification for
ANSI/EIA-364-01B-2000 电连接器和插座用加速度试验程序 Acceleration Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-1000.01A-2006 评定商务办公设备用电器连接件和插座性能的环境试验方法 Environmental Test Methodology for Assessing the Performance of Electrical Connectors and Sockets Used in Business Office Applications
ANSI/EIA-364-101-2000 电连接器、插座、电缆附件或互连系统衰减试验程序 Attenuation Test Procedure for Electrical Connectors, Sockets and Cable Assemblies or Interconnection Systems
ANSI/EIA-364-102-1998 电连接器、插座、电缆附件或互连系统上升时间降低试验程序 Rise Time Degradation Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnection Systems
ANSI/EIA-364-103-1998 电连接器、插座、电缆附件或互连系统传播延迟试验程序 Propogation Delay Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnection Systems
ANSI/EIA-364-106-2000 电连接器和插座的驻波比(SWR)试验程序 Standing Wave Ratio (SWR) Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-107-2000 电连接器、插座、电缆组件或互连系统的眼孔图样和不稳定性试验程序 Eye Pattern and Jitter Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnection Systems
ANSI/EIA-364-11B-2005 电连接器和插座的耐溶剂性试验程序 Resistance to Solvents Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-12A-2005 电连接器和插座的束口试验程序 Restricted Entry Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-13D-2007 电连接器和插座间插拔力的试验程序 Mating and Unmating Force Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-21C-2000 电连接器、插座和同轴触点的绝缘电阻试验程序 Insulation Resistance Test Procedure for Electrical Connectors, sockets and Coaxial Contacts
ANSI/EIA-364-23C-2006 电连接器和插座的低层接触电阻试验程序 Low Level Contact Resistance Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-30A-2002 电连接器和插座的电容试验程序 Capacitance Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-52A-2003 连接器/插座中使用的触点终端的软钎焊性的TP52试验程序 TP 52 Test Procedures for Solderability of Contact Terminations Use in Connectors/Sockets
ANSI/EIA-364-56C-2006 电连接器和插座的耐焊接性加热试验过程 Resistance to Soldering Heat Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-62A-2004 电子连接器和插座的终端强度试验规程TP-62A TP-62A, Terminal Strength Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-70B-2007 电连接器和插座的与电流相对应的温升试验程序 Temperature Rise Versus Current Test Procedure for Electrical Connectors and Sockets
ANSI/EIA-364-80-2002 电连接器和插座的低频屏蔽效果试验程序 Low Frequency Shielding Effectiveness Test Procedure for Electrical Connectors and Sockers
ANSI/EIA-364-81A-2005 电连接器套、连接器组件和插座的燃烧特性试验程序 Combustion Characteristics Test Procedure for Electrical Connector Housing, Connector Assemblies and Sockets
ANSI/EIA-364-82A-2005 电连接器套、连接器组件和插座的塑料腐蚀性试验程序 Corrosivity of Plastics Test Procedure for Electrical Connector Housing, Connector and Socket Housings
ANSI/EIA-364-87-1996 电连接器、触点和插座的纳秒事件探测 Nanosecond Event Detection for Electrical Connectors, Contacts and Sockets
ANSI/EIA-364-89A-2006 航天用电连接器和插座的试验程序 Space Application Test Procedures for Electrical Connectors, and sockets
ANSI/EIA-364-90-2000 电连接器、插座、电缆组件或互联系统用串扰比试验程序 Crosstalk Ratio Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnect Systems
ANSI/EIA-364-91A-2005 电连接器和插座的粉尘试验 Dust Test for Electrical Connectors and Sockets
ANSI/EIA-540A000-A-1990 电子设备用芯片载体插座分规范 Sectional Specification for Sockets for Chip Carriers for Use in Electronic Equipment
ANSI/EIA-540AA00-1991 电子设备用无引线A、B和D型片式载体用片式载体插座的空白详细规范 Chip Carrier Sockets for Leadless type A,B,D Chip Carriers for use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA-540AAAA-1990 电子设备用A型1.27mm(.050")间隔的无引线芯片载体用片式载体插座 Chip Carrier Sockets for Leadless Type A 1.27 mm (.050") Spacing Chip Carriers for Use in Electronic Equipment
ANSI/EIA-540AB00-1991 电子设备用塑料方形扁平封装用片式载体插座的空白详细规范 Chip Carrier Sockets for Plastic Quad Flat Packages for Use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA-540ABAA-1991 塑料方形扁平封装0.635mm(0.25英寸)引线间隔的芯片载体插座的详细规范 Detail Specification for Chip Carrier Sockets for Plastic Quad Flat Pack 0.635-mm (0.25-in) Lead Spacing (Gullwing)
ANSI/EIA-540AC00-1991 电子设备用J型引线塑料片式载体(PCC)封装的片式载体插座的空白详细规范 Chip Carrier Sockets for Plastic Chip Carrier (PCC) Packages with J Type Leads for Use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA-540ACAA-1991 1.27mm(0.50英寸)引线间隔的塑料片式载体系列用片式载体插座的详细规范 Chip Carrier Sockets for Plastic Chip Carrier Family 1.27 mm (0.50 inch) Lead Spacing, Detail Specification for
ANSI/EIA-540AD00-1991 电子设备用插针格栅阵列插座的载体方形扁平组件的适配器用空白详细规范 Adapter-Carrier Quad Flat Pack to Pin Grid Array Sockets for Use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA-540ADAA-1992 电子设备用插针格栅阵列插座的载体方形扁平组件的适配器用详细规范 Adaptor-Carrier Quad Flat Pack to Pin Grid Array Sockets for Use in Electronic Equipment, Detail Specification for
ANSI/EIA-540B000-1989 电子设备用间隔为2.54 mm × 2.54 mm (0.1" × 0.1")的引线格栅阵列(PGA)器件插座的分规范 Sectional Specification for Sockets for Pin-Grid Array Devices with 2.54 mm × 2.54 mm (0.1" × 0.1") Spacing for Use in Electronic Equipment
ANSI/EIA-540B0AA-2001 电子设备用间隔为1.27 mm (0.050英寸)的球形格栅阵列(BGA)插座生产的详细规范 Detail Specification for Production Ball Grid Array (BGA) Sockets with 1.27 mm (0.050 in) Spacing for Use in Electronic Equipment
ANSI/EIA-540B0AE-2000 电子设备用间隔为1.27 mm (0.050 in)的接触面格栅阵列(LGA)插座生产的详细规范 Detail Specification for Production Land Grid Array (LGA) Socket with 1.27 mm (0.050 in) Spacing for Use in Electronic Equipment
ANSI/EIA-540BA00-1990 电子设备用间隔为2.54 mm× 2.54 mm (0.1" × 0.1")的引线格栅阵列(PGA)器件插座的空白详细规范 Blank Detail Specification: Sockets for Pin Grid Array Devices with 2.54 mm × 2.54 mm (0.1" × 0.1") Spacing for Use in Electronic Equipment
ANSI/EIA-540BAAB-1990 电子设备用间隔为2.54 mm× 2.54 mm (0.1" × 0.1")的引线格栅阵列(PGA)器件用非机械操作插座 Non-Mechanically Activated Sockets for Pin Grid Array Devices with 2.54 mm × 2.54 mm (0.1" × 0.1") Spacing for Use in Electronic Equipment
ANSI/EIA-540BAAC-1990 电子设备用引线格栅阵列(PGA)器件的非机械操作柔性载体插座详细规范 Nonmechanically Actuated Flexible Carrier Sockets for Pin Grid Array for Use in Electronic Equipment, Detail Specification for
ANSI/EIA-540C000-1988 电子设备用继电器插座的分规范 Sectional Specification for Sockets for Relays for Use in Electronic Equipment
ANSI/EIA-540CA00-1989 继电器插座的空白详细规范 Blank Detail Specification on Relay Sockets
ANSI/EIA-540CAAA-1989 继电器插座的详细规范.平衡衔铁继电器用10A插座 Detail Specification on Relay Sockets - 10A for Balanced Armature Relay
ANSI/EIA-540CAAB-1989 继电器插座的详细规范.平衡衔铁继电器用5A插座 Detail Specification for Relay Sockets - 5A for Balanced Armature Relay
ANSI/EIA-540CAAC-1998 双极10A继电器插座的详细规范 Detail Specification for 2-Pole 10A Relay Sockets
ANSI/EIA-540CAAD-A-1999 双极5A继电器插座的详细规范 Detail Specification for 2-Pole, 5A Relay Sockets
ANSI/EIA-540CAAE-A-1999 三极10A继电器插座的详细规范 Detail Specification for 3-Pole 10A Relay Sockets
ANSI/EIA-540D000A-1991 电子设备用直插封装插座的分规范 In-Line Package Sockets for Use in Electronic Equipment, Sectional Specification for
ANSI/EIA-540DA00-1991 电子设备用双列直插封装式插座的空白详细规范 Dual-In-Line Package Sockets for Use in Electronic Equipment, Blank Detail Specification for
ANSI/EIA-540DAAB-1991 电子设备用双片双列柔性载体插座的详细规范 Detail Specification for Flexible Carrier 2-Piece Dual-In-Line Socket for Use in Electronic Equipment
ANSI/EIA-540DB00-1993 去耦电容器双列直插封装式插座的空白详细规范 Blank Detail Specification for Decoupling Capacitor Dual-in-Line Package Sockets
ANSI/EIA-540DBAA-1994 电子设备用去耦电容器双列直插封装式插座的详细规范 Detail Specification for Decoupling Capacitor Dual-In-Line Package Sockets for Use in Electronic Equipment
ANSI/EIA-540E000-1992 圆形插座分规范 Sectional Specification for Round Style Sockets
ANSI/EIA-540EA00-1997 圆形插座空白详细规范 Blank Detail Specification for Round Style Sockets
ANSI/EIA-540EAAA-1997 圆形插座详细规范 Detail Specification for Round Style Sockets
ANSI/EIA-540F000-1991 电子设备用多插件模块插座的分规范 Multi-Package Module Sockets for Use in Electronic Equipment, Sectional Specification for
ANSI/EIA-540FAAA-1992 电子设备用100Mil间距多插件、垂直安装的格式模块插座的详细规范 Detail Specification for Multi-Package 100 Mil Pitch, Vertical Mounting Format Module Sockets for Use in Electronic Equipment
ANSI/EIA-540FAAB-1992 电子设备用100Mil间距多插件、定角安装的格式模块插座的详细规范 Detail Specification for Multi-Package 100 Mil Pitch, Angled Mounting Format Module Sockets for Use in Electronic Equipment
ANSI/EIA-540FAAC-1992 电子设备用50Mil间距多插件、垂直安装的格式模块插座的详细规范 Detail Specification for Multi-Package 50 Mil Pitch, Vertical Mounting Format Module Sockets for Use in Electronic Equipment
ANSI/EIA-540FAAD-1992 电子设备用50Mil间距多插件、定角安装的格式模块插座的详细规范 Detail Specification for Multi-Package 50 Mil Pitch, Angled Mounting Format Module Sockets for Use in Electronic Equipment
ANSI/EIA-540G000-1993 电子设备用烧进插座的分规范 Sectional Specification for Burn-In Sockets for Use in Electronic Equipment
ANSI/EIA-540GA00-1993 电子设备用带模压载体环的片式载体封装烧进插座的空白详细规范 Blank Detail Specification for Burn-In Socket for Chip Carrier Packages with Molded Carrier Rings for Use in Electronic Equipment
ANSI/EIA-540GAAA-1993 电子设备用带模压载体环的片式载体封装烧进插座的详细规范 Detail Specification for Burn-In Sockets for Chip Carrier Packages with Molded Carrier Rings for Use with Electronic Equipment
ANSI/EIA-540H000-1997 电子设备用球形格栅阵列(BGA)器件烧结插座的分规范 Sectional Specification for Burn-In Sockets Used with Ball Grid Array Devices for Use in Electronic Equipment
ANSI/EIA-540HA00-2000 电子设备用球形格栅阵列(BGA)器件烧接插座的空白详细规范 Blank Detail Specification for Burn-In Sockets Used with Ball Grid Array Devices for Use in Electronic Equipment
ANSI/EIA-540HAAA-2000 电子设备用球形格栅阵列(BGA)器件烧进插座的详细规范 Detail Specification for Burn-In Sockets Used with Ball Grid Array Devices for Use in Electronic Equipment
ANSI/EIA/CEA 364-28E-2006 电连接器和插座的振动试验程序 Vibration Test Procedure for Electrical Connectors and Sockets
ANSI/EIA/CEA 364-59A-2006 电子连接器和插座的低温试验程序 Low Temperature Test Procedure for Electrical Connectors and Sockets
ANSI/EIA/ECA 364-18B-2007 电连接和插座用视觉和空间检验试验规程 Visual and Dimensional Inspection Test Procedure for Electrical Connectors and Sockets
ANSI/NEMA FB-11-2000 危险位置用插针和套管式的插头、插座和连接器 Plugs, Receptacles, and Connectors of the Pin and Sleeve Type for Hazardous Locations
ANSI/SCTE 01-2006 "F"端口(室外用插座)物理尺寸 "F" Port (Female Outdoor) Physical Dimensions
ANSI/STCE SP406-1998 "F"入口(室内插座)物理尺寸 "F" Port (Female Indoor) Physical Dimensions
ANSI/UL 414-2006 仪表插座的安全标准 Standard for Safety for Meter Sockets
ANSI/UL 498-2007 连接插头和插座安全性的标准 Standard for Safety for Attachment Plugs and Receptacles (Proposal dated April 6, 2007)
ANSI/UL 498A-2003 分插座和转接器的安全标准 Standard for Safety for Current Taps and Adapters
IEEE C 12.7-1993 电度表插座技术要求 (Requirements for watthour meter sockets)
IEEE C 12.8-1981 自含A底插座电度表安装用测试块和测试盒 (Test blocks and cabinets for installation of self-containded A-base watthour meters)
IEEE C 136.10-1996 道路照明设备.锁紧式光控制设备和配套插座结构和电气互换性及检验 (Roadway lighting equipment - Locking-type photocontrol devices and mating receptacle physical and electrical interchangeability and testing)
IEEE C 136.11-1995 道路照明设备.并联插座 (Roadway Lighting Equipment - Multiple Sockets)
IEEE C 136.4-1995 道路照明设备.串联插座和串联插座头 (Roadway Lighting Equipment - Series Sockets and Series-Socket Receptacles)
IEEE C 136.4/ANSI C 136.4-1995 道路照明设备系列插座和系列插座孔 (Roadway Lighting Equipment - Series Sockets and Series-Socket Receptacles)
UL 1010-1995 危险(分类的)场所用插座插头组合件 (Receptacle-plug combinations for use in hazardous (classified) locations )
UL 1567-1998 铝线用插座和开关 (Receptacles and switches intended for use with aluminium wire )
UL 231-1998 电源插座 (Power outlets )
UL 498-1996 连接插头和插座 (Attachment plugs and receptacles )
UL 879-1997 气体放电信号管用电极插座 (Electrode receptacles for gas-tube signs )
编号 中文名称 英文名称
编号 中文名称 英文名称
编号 中文名称 英文名称
@阿牛888
NEMA6-20R只是此插座的代号,但是还是要谢谢你!
请您参考,如需更多详细的资料,欢迎联系.maid@163.com
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/76/655631239242390.png');}" onmousewheel="return imgzoom(this);">
