关于反激式电源变压器设计的一个问题.
最近在一篇资料看到了这样一段话:
in a flyback transformer with multiple winding,the primary turns may be constrained to specific multiples such as 22,44,66,88,etc,because of turns ratio considerations.
in this case if Nmin is 36 turns the smallest possible N is 44 turns.It may be that these additional turns above the minimum will not fit the core unless the actual core area product is sufficiently greater than the minimum AP calculated in Equation 1
这里是在说反激式的原边绕组只能是22,44,66,88,这几个值吗,如果不是那这段话到底是什么意思?
这段话出自Lloyd H.Dixon.Jr的
FILTER INDUCTOR AND FLYBACK TRANSFORMER DESIGN FOR SWITCHING POWER SUPPLIES
手上现在没有电子版,只能手打一部分
全部回复(0)
