我现在正在做同步整流的实验,在实际电路上出现了一些问题,就想用PSPICE仿真进行验证,可是没有IRL3803的模型库,各位大侠有什么高招。
PS:我用的是ORCAD9.23。
求助IRL3803的仿真模型库
全部回复(11)
pspice 的模型
.SUBCKT irl3803 1 2 3
* Model Generated by MODPEX *
*Copyright(c) Symmetry Design Systems*
* All Rights Reserved *
* UNPUBLISHED LICENSED SOFTWARE *
* Contains Proprietary Information *
* Which is The Property of *
* SYMMETRY OR ITS LICENSORS *
*Commercial Use or Resale Restricted *
* by Symmetry License Agreement *
* Model generated on Oct 1, 01
* MODEL FORMAT: SPICE3
* Symmetry POWER MOS Model (Version 1.0)
* External Node Designations
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
M1 9 7 8 8 MM L=100u W=100u
.MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=2.19991 LAMBDA=0.066277 KP=242.082
+CGSO=3.4e-05 CGDO=1e-11
RS 8 3 0.00374412
D1 3 1 MD
.MODEL MD D IS=9.10142e-10 RS=0.00293788 N=1.24499 BV=30
+IBV=0.00025 EG=1.00067 XTI=2.50514 TT=0.0001
+CJO=4.09446e-09 VJ=2.08848 M=0.483177 FC=0.5
RDS 3 1 1e+06
RD 9 1 0.0001
RG 2 7 5.27356
D2 4 5 MD1
* Default values used in MD1:
* RS=0 EG=1.11 XTI=3.0 TT=0
* BV=infinite IBV=1mA
.MODEL MD1 D IS=1e-32 N=50
+CJO=2.712e-09 VJ=1.09073 M=0.714038 FC=1e-08
D3 0 5 MD2
* Default values used in MD2:
* EG=1.11 XTI=3.0 TT=0 CJO=0
.MODEL MD2 D IS=1e-10 N=0.4 RS=3e-06
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 4.39906e-09
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
* Default values used in MD3:
* RS=0 BV=infinite IBV=1mA
.MODEL MD3 D IS=1e-10 N=0.4
.ENDS irl3803
saber的模型
template irl3803 d g s
# Model Generated by MODPEX *
#Copyright(c) Symmetry Design Systems*
# All Rights Reserved *
# UNPUBLISHED LICENSED SOFTWARE *
# Contains Proprietary Information *
# Which is The Property of *
# SYMMETRY OR ITS LICENSORS *
#Commercial Use or Resale Restricted *
# by Symmetry License Agreement *
# Model generated on Oct 1, 01
# MODEL FORMAT: Saber
# Symmetry POWER MOS Model (Version 1.0)
# External Node Designations
# Node d -> Drain
# Node g -> Gate
# Node s -> Source
electrical d,g,s
# BODY_BEGIN
spm..model mm=(type=_n,
level=1,is=1e-32,rd=1e-6,
vto=2.19991,lambda=0.066277,kp=242.082,rs=0.00374412,
cgso=3.4e-05,cgdo=1e-11)
spd..model md=(is=9.10142e-10,rs=0.00293788,n=1.24499,bv=30,
ibv=0.00025,eg=1.00067,xti=2.50514,tt=0.0001,
cjo=4.09446e-09,vj=2.08848,m=0.483177,FC=0.5)
# Default values used in MD1:
# RS=0 EG=1.11 XTI=3.0 TT=0
# BV=infinite IBV=1mA
spd..model md1=(is=1e-32,n=50,
cjo=2.712e-09,vj=1.09073,m=0.714038,fc=1e-08)
# Default values used in MD2:
# EG=1.11 XTI=3.0 TT=0 CJO=0
spd..model md2=(is=1e-10,n=0.4,rs=3e-06)
# Default values used in MD3:
# RS=0 BV=infinite IBV=1mA
spd..model md3=(is=1e-10,n=0.4)
spm.M1 n9 n7 s s =model=mm,l=100u,w=100u
spd.d1 s d =model=md
spr.rds s d =1e+06
spr.rd n9 d =0.0001
spr.rg g n7 =5.27356
spd.d2 n4 n5 =model=md1
spd.d3 0 n5 =model=md2
spr.rl n5 n10 =1
spf.fi2 n7 n9 i(spv.vfi2) =-1
spv.vfi2 n4 0 =0
spe.ev16 n10 0 n9 n7 =1
spc.cap n11 n10 =4.39906e-09
spf.fi1 n7 n9 i(spv.vfi1) =-1
spv.vfi1 n11 n6 =0
spr.rcap n6 n10 =1
spd.d4 0 n6 =model=md3
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
RS 8 3 0.00374412
D1 3 1 MD
RDS 3 1 1e+06
RD 9 1 0.0001
RG 2 7 5.27356
D2 4 5 MD1
D3 0 5 MD2
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
.ENDS irl3803
saber的模型
# Node d -> Drain
# Node g -> Gate
# Node s -> Source
electrical d,g,s
# BODY_BEGIN
spr.rds s d =1e+06
spr.rd n9 d =0.0001
spr.rl n5 n10 =1
spv.vfi2 n4 0 =0
spv.vfi1 n11 n6 =0
spr.rcap n6 n10 =1
@tinyhe
pspice的模型.SUBCKTirl3803123*************************************** ModelGeneratedbyMODPEX **Copyright(c)SymmetryDesignSystems** AllRightsReserved ** UNPUBLISHEDLICENSEDSOFTWARE ** ContainsProprietaryInformation** WhichisThePropertyof ** SYMMETRYORITSLICENSORS **CommercialUseorResaleRestricted** bySymmetryLicenseAgreement ****************************************ModelgeneratedonOct 1,01*MODELFORMAT:SPICE3*SymmetryPOWERMOSModel(Version1.0)*ExternalNodeDesignations*Node1->Drain*Node2->Gate*Node3->SourceM19788MML=100uW=100u.MODELMMNMOSLEVEL=1IS=1e-32+VTO=2.19991LAMBDA=0.066277KP=242.082+CGSO=3.4e-05CGDO=1e-11RS830.00374412D131MD.MODELMDDIS=9.10142e-10RS=0.00293788N=1.24499BV=30+IBV=0.00025EG=1.00067XTI=2.50514TT=0.0001+CJO=4.09446e-09VJ=2.08848M=0.483177FC=0.5RDS311e+06RD910.0001RG275.27356D245MD1*DefaultvaluesusedinMD1:* RS=0EG=1.11XTI=3.0TT=0* BV=infiniteIBV=1mA.MODELMD1DIS=1e-32N=50+CJO=2.712e-09VJ=1.09073M=0.714038FC=1e-08D305MD2*DefaultvaluesusedinMD2:* EG=1.11XTI=3.0TT=0CJO=0* BV=infiniteIBV=1mA.MODELMD2DIS=1e-10N=0.4RS=3e-06RL5101FI279VFI2-1VFI2400EV16100971CAP11104.39906e-09FI179VFI1-1VFI11160RCAP6101D406MD3*DefaultvaluesusedinMD3:* EG=1.11XTI=3.0TT=0CJO=0* RS=0BV=infiniteIBV=1mA.MODELMD3DIS=1e-10N=0.4.ENDSirl3803saber的模型templateirl3803dgs#*************************************# ModelGeneratedbyMODPEX *#Copyright(c)SymmetryDesignSystems*# AllRightsReserved *# UNPUBLISHEDLICENSEDSOFTWARE *# ContainsProprietaryInformation*# WhichisThePropertyof *# SYMMETRYORITSLICENSORS *#CommercialUseorResaleRestricted*# bySymmetryLicenseAgreement *#*************************************#ModelgeneratedonOct 1,01#MODELFORMAT:Saber#SymmetryPOWERMOSModel(Version1.0)#ExternalNodeDesignations#Noded->Drain#Nodeg->Gate#Nodes->Sourceelectricald,g,s{#BODY_BEGINspm..modelmm=(type=_n,level=1,is=1e-32,rd=1e-6,vto=2.19991,lambda=0.066277,kp=242.082,rs=0.00374412,cgso=3.4e-05,cgdo=1e-11)spd..modelmd=(is=9.10142e-10,rs=0.00293788,n=1.24499,bv=30,ibv=0.00025,eg=1.00067,xti=2.50514,tt=0.0001,cjo=4.09446e-09,vj=2.08848,m=0.483177,FC=0.5)#DefaultvaluesusedinMD1:# RS=0EG=1.11XTI=3.0TT=0# BV=infiniteIBV=1mAspd..modelmd1=(is=1e-32,n=50,cjo=2.712e-09,vj=1.09073,m=0.714038,fc=1e-08)#DefaultvaluesusedinMD2:# EG=1.11XTI=3.0TT=0CJO=0# BV=infiniteIBV=1mAspd..modelmd2=(is=1e-10,n=0.4,rs=3e-06)#DefaultvaluesusedinMD3:# EG=1.11XTI=3.0TT=0CJO=0# RS=0BV=infiniteIBV=1mAspd..modelmd3=(is=1e-10,n=0.4)spm.M1n9n7ss=model=mm,l=100u,w=100uspd.d1sd=model=mdspr.rdssd=1e+06spr.rdn9d=0.0001spr.rggn7=5.27356spd.d2n4n5=model=md1spd.d30n5=model=md2spr.rln5n10=1spf.fi2n7n9i(spv.vfi2)=-1spv.vfi2n40=0spe.ev16n100n9n7=1spc.capn11n10=4.39906e-09spf.fi1n7n9i(spv.vfi1)=-1spv.vfi1n11n6=0spr.rcapn6n10=1spd.d40n6=model=md3}
我昨天用MODEL EDITOR建了模,但是调用到CPATURE中,不认,这是怎么回事?
我的步骤是:打开MODEL EDITOR,IMPORT-IRL3803的文本文件,以IRL3803存盘,再CREAT capture parts,将.lib转成.olb。文件名相同。
打开CAPTURE,OPEN-IRL3803库,再双击IRL3803这个元件,这时出现的是一个集成块的图像。这时无论是否对它的外观进行修改,编辑它的属性及封装,后存盘退出。在CAPUTPR中调用这个元件,都显示ERROR -- Subcircuit IRL3803 used by X_U1 is undefined。这是怎么回事?PART property 是X^@REFDES %1 %2 %3 @MODEL 。我也对它进行了更改,没用。整整一天,我头都大了。各位帮忙解决一下!!!!
PIN的属性我也改过,PASSIVE或INPUT都试过。
@littledrop
我昨天用MODELEDITOR建了模,但是调用到CPATURE中,不认,这是怎么回事?我的步骤是:打开MODELEDITOR,IMPORT-IRL3803的文本文件,以IRL3803存盘,再CREATcaptureparts,将.lib转成.olb。文件名相同。 打开CAPTURE,OPEN-IRL3803库,再双击IRL3803这个元件,这时出现的是一个集成块的图像。这时无论是否对它的外观进行修改,编辑它的属性及封装,后存盘退出。在CAPUTPR中调用这个元件,都显示ERROR--SubcircuitIRL3803usedbyX_U1isundefined。这是怎么回事?PARTproperty是X^@REFDES%1%2%3@MODEL。我也对它进行了更改,没用。整整一天,我头都大了。各位帮忙解决一下!!!!PIN的属性我也改过,PASSIVE或INPUT都试过。
我给你做了这个器件,你试试看
1083652643.rar
1083652643.rar
@littledrop
出现同样的错误。显示ERROR--SubcircuitIRL3803usedbyX_U1isundefined。
将库文件添加到项目中
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/17/1084104580.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/17/1084104580.jpg?x-oss-process=image/format,webp)
@tinyhe
将库文件添加到项目中[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/17/1084104580.jpg');}"onmousewheel="returnimgzoom(this);">
成功!多谢tinyhe
@tinyhe
你好,我怎么按你的去做,但仿真时出现:
ERROR -- Less than 2 connections at node N00951
ERROR -- Node X_M1.7 is floating
ERROR -- Node N00951 is floating
什么问题啊,谢谢!
什么问题啊,谢谢!
