大电流传感器 ACS754LCB-100-PFF 100A 英文资料
Features and Benefits
Monolithic Hall IC for high reliability
Single +5 V supply
3 kVRMS isolation voltage between terminals 4/5 and pins 1/2/3
35 kHz bandwidth
Automotive temperature range
End-of-line factory-trimmed for gain and offset
Ultra-low power loss: 100 µΩ internal conductor resistance
Ratiometric output from supply voltage
Extremely stable output offset voltage
Small package size, with easy mounting capability
Output proportional to ac and dc currents
Description
The Allegro ACS75x family of current sensors provides economical and precise solutions for current sensing in industrial, automotive, commercial, and communications systems. The device package allows for easy implementation by the customer. Typical applications include motor control, load detection and management, power supplies, and overcurrent fault protection.
The device consists of a precision, low-offset linear Hall sensor circuit with a copper conduction path located near the die. Applied current flowing through this copper conduction path generates a magnetic field which is sensed by the integrated Hall IC and converted into a proportional voltage. Device accuracy is optimized through the close proximity of the magnetic signal to the Hall transducer. A precise, proportional voltage is provided by the low-offset, chopper-stabilized BiCMOS Hall IC, which is programmed for accuracy at the factory.
The output of the device has a positive slope (>VCC / 2) when an increasing current flows through the primary copper conduction path (from terminal 4 to terminal 5), which is the path used for current sensing. The internal resistance of this conductive path is typically 100 µΩ, providing low power loss. The thickness of the copper conductor allows survival of the device at up to 5x overcurrent conditions. The terminals of the conductive path are electrically isolated from the sensor leads (pins 1 through 3). This allows the ACS75x family of sensors to be used in applications requiring electrical isolation without the use of opto-isolators or other costly isolation techniques.
The device is fully calibrated prior to shipment from the factory. The ACS75x family is lead-free. All leads are coated with 100% matte tin, and there is no lead inside the package. The heavy gauge leadframe is made of oxygen-free copper.
Functional Block Diagram
Part Number Package Type RoHS Temperature
Compliant
ACS754SCB-100-PFF  5-lead CB  Yes -20 °C to  85 °C
ACS754SCB-200-PFF  5-lead CB  Yes -20 °C to  85 °C
ACS754KCB-150-PFF  5-lead CB  Yes -40 °C to  125 °C
ACS754LCB-050-PFF  5-lead CB  Yes -40 °C to  150 °C
ACS754LCB-100-PFF  5-lead CB  Yes -40 °C to  150 °C
ACS754LCB-130-PFF  5-lead CB  Yes -40 °C to  150 °C
24小时专线:13684976689, 陈小姐
QQ:744658389 .
MSN:chen2010123@hotmail.com.
E-mail:chenling2008456@163.com.
霍尔齿轮传感器,霍尔电流传感器,节气门位置传感器,变速箱速度和方向检测,ABS速度检测,凸轮轴和曲轴位置检测等汽车专用传感器及电机驱动IC专卖,
全部回复(0)
