请告知这种控制板的生产厂家?IC1模块是31脚的,哪里有卖的?
谢谢!
哪位知道这种仿松下KR500控制板的生产厂家和它所采用的IC1模块?
全部回复(19)
@惠龙乾
正面图
正面图
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/77/660791243006603.jpg');}" onmousewheel="return imgzoom(this);">
反面图
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/77/660791243006663.jpg');}" onmousewheel="return imgzoom(this);">
IC1模块反面局部图(31脚)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/77/660791243006735.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/77/660791243006603.jpg?x-oss-process=image/format,webp)
反面图
![](http://u.dianyuan.com/bbs/u/77/660791243006663.jpg?x-oss-process=image/format,webp)
IC1模块反面局部图(31脚)
![](http://u.dianyuan.com/bbs/u/77/660791243006735.jpg?x-oss-process=image/format,webp)
@惠龙乾
正面图[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/77/660791243006603.jpg');}"onmousewheel="returnimgzoom(this);">反面图[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/77/660791243006663.jpg');}"onmousewheel="returnimgzoom(this);">IC1模块反面局部图(31脚)[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/77/660791243006735.jpg');}"onmousewheel="returnimgzoom(this);">
上面写的“通用”啊
@惠龙乾
惠工,这是上海通用的控制板,你的机子是通用的吗?
@惠龙乾
感谢以上各位的热情帮助!
前几天忙没上网,所以没有及时回复各位,对不起!
我在控制板上没发现有通用的字样,这批控制板是朋友邮寄过来修的,所以不知道这种控制板用在什么牌子的焊机上的,经过我检查确定有部分控制板是IC1模块坏了,需更换,请大家看看谁有这种IC1模块?留下电话、供货方式、价格及我的付款方式.
再次感谢大家的热心!
陕西宝鸡
再次感谢大家的热心!
陕西宝鸡
这个模块一般都买不到的.找找坏板子上有没有.以前给他们更换很多KR主板!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/77/3303851243490261.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/77/3303851243490275.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/77/3303851243490287.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/77/3303851243490261.jpg?x-oss-process=image/format,webp)
![](http://u.dianyuan.com/bbs/u/77/3303851243490275.jpg?x-oss-process=image/format,webp)
![](http://u.dianyuan.com/bbs/u/77/3303851243490287.jpg?x-oss-process=image/format,webp)
@惠龙乾
感谢以上各位的热情帮助! 前几天忙没上网,所以没有及时回复各位,对不起! 我在控制板上没发现有通用的字样,这批控制板是朋友邮寄过来修的,所以不知道这种控制板用在什么牌子的焊机上的,经过我检查确定有部分控制板是IC1模块坏了,需更换,请大家看看谁有这种IC1模块?留下电话、供货方式、价格及我的付款方式. 再次感谢大家的热心! 陕西宝鸡
正面
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/77/3303851243490573.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/77/3303851243490573.jpg?x-oss-process=image/format,webp)
@nobilis
这个模块一般都买不到的.找找坏板子上有没有.以前给他们更换很多KR主板![图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/77/3303851243490261.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/77/3303851243490275.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/77/3303851243490287.jpg');}"onmousewheel="returnimgzoom(this);">
谢谢!
我再想想别的办法,若有效了再给你说,
我再想想别的办法,若有效了再给你说,
@惠龙乾
控制板的正面图和反面图及IC1模块的管脚部分图,是31脚的,但其大小和松下原装的一样.
此板有啊! 整板和IC1都有的. 13435428758 高成焊接
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/77/3295221243605403.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/77/3295221243605403.jpg?x-oss-process=image/format,webp)
