spwm电源
各位高手,小弟用dspic30f3010写的spwm波的程序,结果波形不规范,请帮忙看一下,哪里有问题,谢谢
#include "p30fxxxx.h"
#define XTFREQ                 5000000  // xtal = 5Mhz;
#define PLLMODE                     16  // PLLx16
#define FCY           XTFREQ*PLLMODE/4  // Instruction Cycle Frequency
//      FCY                   20000000  // 20 MIPS
#define FPWM                     12800  // 12.8 kHz, so that no audible noise is present.
unsigned int Phase;      //  0..65535
int DutyCycle;  //  0..28300
void InitMCPWM();
void InitTMR1();
void Run();
const  int sintable[64]={0,3212,6393,9512,12539,15446,18204,20787,23170,25329,
27245,28898,30273,31356,32137,32609,32767,32609,32137,31356,30273,28898,
27245,25329,23170,20787,18204,15446,12539,9512,6393,3212,0,-3212,-6393,
-9512,-12539,-15446,-18204,-20787,-23170,-25329,-27245,-28898,-30273,
-31356,-32137,-32609,-32767,-32609,-32137,-31356,-30273,-28898,-27245,
-25329,-23170,-20787,-18204,-15446,-12539,-9512,-6393,-3212 };
void __attribute__((interrupt, no_auto_psv)) _PWMInterrupt (void)
IFS2bits.PWMIF = 0; // Clear interrupt flag
    if( Phase>64 )
      Phase=0;
    Phase=Phase%64;
    SPWM( DutyCycle, Phase ); // rotate stator
Phase ++;    // Increment Phase if CW to generate the
    return;
int main( void )
    InitMCPWM();
CORCONbits.PSV = 1;
    DutyCycle = 1; // <------- set duty cycle
    Phase = 0;
    SPWM( DutyCycle, Phase ); // rotate stator field and wait rotor response
    Run();
    while( 1 ) /* or use !SWITCH_S2 here for S2 to stop test */
    return 0;
void Run void )
    unsigned int i;
    OVDCON = 0x0015; // charge bootstrap cap
    for( i = 0; i < 40000; i++ ) Nop();
    PWMCON2bits.UDIS = 1;       // PWM update lock
//    PDC1 = PDC2 = PDC3 = PTPER; // Initialize as 0 voltage
    OVDCON = 0x3F00;            // Configure PWM0-5 to be governed by PWM module
    PWMCON2bits.UDIS = 0;       // PWM update unlock
IEC2bits.PWMIE = 1; // Enable PWM interrupts
    return;
void InitMCPWM( void )
    TRISE = 0x0100;             // PWM pins as outputs, and FLTA as input
    PTPER = ( FCY / FPWM - 1 ) >> 1; // Compute Period based on CPU speed and
    // required PWM frequency (see defines)
    OVDCON = 0x0000;            // Disable all PWM outputs.
    DTCON1 = 0x001F;            // 2us of dead time
    PWMCON1 = 0x0077;           // Enable PWM output pins and configure them as
                                // complementary mode
    IEC2bits.PWMIE = 0;         // Disable PWM interrupts
    PDC1 = PTPER;               // Initialize as 0 voltage
    PDC2 = PTPER;               // Initialize as 0 voltage
//    PWMCON2 = 0x0F02;           // 16 postscale values, for achieving 20 kHz
    PWMCON2 = 0x0202;
    PTCON = 0x8002;             // start PWM as center aligned mode
FLTACON = 0x0000; // Initialize Fault Controls
    return;
void SPWM( int volts, unsigned int angle )
    unsigned int angle1, angle2, angle3;
    int sin_1, sin_2, sin_3;
    angle1=angle;
    angle2=(angle1+21)%64;
    angle3=(angle2+21)%64;
sin_1 = volts * sintable[angle1]>>6;
sin_2 = volts * sintable[angle2]>>6;
sin_3 = volts * sintable[angle3]>>6;
// 1
if( sin_1<0 )
sin_1 = sin_1+PTPER;
if(sin_1 >= 780)
     sin_1 = 780; //限幅
// 2
if( sin_2<0 )
sin_2=sin_2+PTPER;
if(sin_2 >= 780)
     sin_2 = 780; //限幅
// 3
if( sin_3<0 )
sin_3=sin_3+PTPER;
if(sin_3 >= 780)
     sin_3 = 780; //限幅
     PDC1=sin_1;
     PDC2=sin_2;
     PDC3=sin_3;
}                               // end SPWM()
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/579731245760030.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/579731245760038.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(2)
fsyuri
看不懂,但帮你顶一下
liaohu699
应该是一个可调输出电压三相120°的spwm程序.但是问题多多呀.比如你的频率咋调呀?
