请教各位大侠!!!这是DCM还是CCM(单端反激DC-DC变换)
最近在做一个单端反激变换器,输入48V,输出8.4V-2.8A(满载)
下图是Vds波形:负载分别是0.7A,1.4A,和2.8A,想问各是什么工作模式???500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/3388341245849658.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/3388341245849671.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/3388341245849685.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(15)
chenglg
上左图为负载0.7A,上右图为负载1.4A,
下方图为负载2.8A
chenglg
@chenglg
上左图为负载0.7A,上右图为负载1.4A,下方图为负载2.8A
特别是想知道:负载是1.4A的时候Vds波形是否正常?500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/3388341245850135.jpg');}" onmousewheel="return imgzoom(this);">
东方龙
@chenglg
特别是想知道:负载是1.4A的时候Vds波形是否正常?[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/78/3388341245850135.jpg');}"onmousewheel="returnimgzoom(this);">
环路没调好
chenglg
@东方龙
环路没调好
请教楼上的DX,为什么满载2.8A,和轻载0.7A都是正常的波形,而负载1.4A时波形会这样呢
chenglg
@chenglg
而且输出纹波里感觉有很大的干扰,像是开关管切换时候造成了冲击,有什么解决方法吗?500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/3388341245894619.jpg');}" onmousewheel="return imgzoom(this);">
chenglg
@chenglg
而且输出纹波里感觉有很大的干扰,像是开关管切换时候造成了冲击,有什么解决方法吗?[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/78/3388341245894619.jpg');}"onmousewheel="returnimgzoom(this);">
部分电路原理图如下500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/3388341245897455.jpg');}" onmousewheel="return imgzoom(this);">
chenglg
@chenglg
部分电路原理图如下[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/78/3388341245897455.jpg');}"onmousewheel="returnimgzoom(this);">
高手在哪里呢?
东方龙
@chenglg
高手在哪里呢?
把431的RC补偿R:10K ,C:104试试.
chenglg
@chenglg
高手在哪里呢?
自己顶个
chenglg
@东方龙
把431的RC补偿R:10K,C:104试试.
实际上,R已经是100K,C已经是4700pF了
东方龙
@chenglg
自己顶个
环路增益太大,容易产生振荡,建仪C从102-104固定,R用200K电位器反复调整,肯定能调到一个稳定点.
东方龙
@东方龙
D7装了没有?
lf8754321lf
@东方龙
D7装了没有?
确实是反馈不稳,4700P太小了,改104或473+1K电阻试试看.将反馈采样放在L2前面可能回好一些(应为L2加大了相位延后).
东方龙
@lf8754321lf
R9是驱动限流电阻,一般取4.7-47R左右.
heruogu
@chenglg
VDS波形不正常,出线了大小波,看看此时的开关管的驱动就知道,占空比不一样。
应该是环路的问题,可以调节的地方光耦的反馈电容,以及次级光耦供电电阻
