白金机请教--有图
自己做的一台白金机,铁芯是2.2*2*16,初
级1.8两层约90匝,次级0.63绕6层约1000匝,电容是30UF的,白金是接触器
触头改的,空载时输出电压260V,电流2.88A带100W灯泡时只有140几V电流4.1A
高手看看我这个JJ的性能可否提高?
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/3330551249630610.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/3330551249630660.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/3330551249630873.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/3330551249631490.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(22)
初级匝数太少了.
@云影浪砂
初级匝数太少了.
初级匝数多少算合理?
我觉得这机子电压太低了效果很差的.电压还不稳的.有没有高手帮我看看怎么改一下?
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/3330551249631387.jpg');}" onmousewheel="return imgzoom(this);">
还有就是这个次级层间绝缘大家是用什么材料的?我用的这个是不是太厚了?
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/3330551250213234.jpg');}" onmousewheel="return imgzoom(this);">
@yzw2003328
初级匝数多少算合理?
电压不稳,好象是白金的事,触点不行
@yzw2003328
我觉得这机子电压太低了效果很差的.电压还不稳的.有没有高手帮我看看怎么改一下?[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/80/3330551249631387.jpg');}"onmousewheel="returnimgzoom(this);">还有就是这个次级层间绝缘大家是用什么材料的?我用的这个是不是太厚了?[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/80/3330551250213234.jpg');}"onmousewheel="returnimgzoom(this);">
你射那么多精在上面干嘛?
机械部分不好.支架不合理.
@云影浪砂
初级匝数太少了.
云影浪砂 称号:学徒  积分: 28分 发帖: 7帖 第3帖
   初级匝数太少了.
    怎么说? 我说初级匝数多了
cxyn
@892800264
机械部分不好.支架不合理.
看你的参数基本上就是输出直流电了.用4~10uf电容试试保证空载你那个表烧掉.频率太高就减少初级匝数(70匝就够了…
@cxyn
路过
狩鱼人
@cxyn
从所调的电流来看,功率才49.2W,这么小的功率,铁心不会饱和,所以初级90匝也不能算少.
dhlh9615
@狩鱼人
加到120匝试试
yzw2003328
@dhlh9615
加到120匝试试
看了这多人的意见真不知是加好还是减好,先加到120试试吧.
渔公鸟
@yzw2003328
你的初级匝数差不多,不用加.只是铁芯相对有点小,可以加大一点试试.电容不用30UF,在15UF左右就差不多了.电压不稳的主要原因是触点不行,我说过很多次,接触器的触头不适合做白金机,但就是没人信.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/2687331251989351.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/2687331251989368.jpg');}" onmousewheel="return imgzoom(this);">
@892800264
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/81/2687331251989351.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/81/2687331251989368.jpg');}"onmousewheel="returnimgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/2687331251989420.jpg');}" onmousewheel="return imgzoom(this);">
@892800264
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/81/2687331251989420.jpg');}"onmousewheel="returnimgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/2687331251989454.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/2687331251989470.jpg');}" onmousewheel="return imgzoom(this);">
esbod
初次级比是1:4-6 初级90匝次级300匝足够了,次级线1.0MM以上,接个100W灯泡电压最多100V但是峰值超过1200V,靠的就是这1000多V的峰值刺激鱼(深度),靠的就是这100V定住鱼(浮鱼),频率靠电容调节100UF以上油浸(成本有点高想要效果就得付出)
  白金机其实是交流直流交替输出的,触点断开时铁心磁性消失一瞬间产生磁切割产生的1000多V峰值直流电压(牛逼的地方就在这里)
esbod
你哪次级1000多匝电压有点高了,内阻又大输出电流偏小而电压偏高,电容又小频率高了点,会沉鱼的
jng111
有没搞错???这是白金机电流????
@esbod
初次级比是1:4-6初级90匝次级300匝足够了,次级线1.0MM以上,接个100W灯泡电压最多100V但是峰值超过1200V,靠的就是这1000多V的峰值刺激鱼(深度),靠的就是这100V定住鱼(浮鱼),频率靠电容调节100UF以上油浸(成本有点高想要效果就得付出)  白金机其实是交流直流交替输出的,触点断开时铁心磁性消失一瞬间产生磁切割产生的1000多V峰值直流电压(牛逼的地方就在这里)
300圈就行了????
开机的时候把起子轻轻放衔铁表面,灯泡有亮点不?要是有的话支架还要改进下!大多少数是支架做不好
