请问在GS/CE等认证中的电压残留测试的具体要求是怎样的?
请问在GS/CE等认证中的电压残留测试的具体要求是怎样的?我记得是拔插头后1秒钟内,电容两端电压必须降到安全电压以下45V还是36,不记得了.
全部回复(1)
朱贵和
终于打到了,大抄下来大家分享:
60335-1的22.5条
34V
22.5 Appliances intended to be connected to the supply mains by means of a plug shall be
constructed so that in normal use there is no risk of electric shock from charged capacitors
when the pins of the plug are touched.
NOTE Capacitors having a rated capacitance up to 0,1 μF are not considered to entail a risk of electric shock.
Compliance is checked by the following test.
The appliance is supplied at rated voltage. Any switch is then placed in the off position and
the appliance is disconnected from the supply mains at the instant of voltage peak. One
second after disconnection, the voltage between the pins of the plug is measured with an
instrument that does not appreciably affect the value to be measured.
The voltage shall not exceed 34 V.
