2串 3串锂电池充电器,三档电流设定,红蓝双灯充满转灯自停.有外壳.
输入4.8-9V(不可使用工频变压器,即老式很重的铁块)
充电电流:拨上1号开关250mA
拨上2号开关700mA
同时拨上12开关1000mA
无电池接入蓝灯亮,红灯弱闪.
充电红灯亮,充满转灯自停.
充电需要将4根线都接入电池正负及抽头.
![](http://u.dianyuan.com/bbs/u/80/2921921251690448.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/2921921251690448.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
红黄白黑四线,分别连接电池从高到低四处,如图连接.
![](http://u.dianyuan.com/bbs/u/80/2921921251690491.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/2921921251690491.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
无电池状态,蓝灯亮,红灯弱闪.
![](http://u.dianyuan.com/bbs/u/80/2921921251690551.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/2921921251690551.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
给3串锂电池充电.只有2节18650电池,最后一节用小锂电池跑龙套.
![](http://u.dianyuan.com/bbs/u/80/2921921251690593.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/2921921251690593.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
给两节18650锂电池充电.
![](http://u.dianyuan.com/bbs/u/80/2921921251690632.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/2921921251690632.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
配备合适塑料盒,已开槽开孔.(全部手开,所以不完美,请见谅)
![](http://u.dianyuan.com/bbs/u/80/2921921251690663.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/2921921251690663.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/80/2921921251690698.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/2921921251690698.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
盒子盖都是卡口,可以随意掰开,调整开关电流.
懂电子的朋友肯定会想到,这个方案一个问题,就是三个充电芯片不会同时关断,也就是同时给三个电池充电,充电关断电压是不同的,正常的TP4056精度是1%,但是为了方便解决这个问,芯片筛选,精度都在0.5%以内,而且每三个芯片电压之差不超过10mV,也就是最高的一颗是4.20的话,最低的一颗不低于4.190.这样最大限度的减小了这个问题.
三串锂电池充电知识:三串锂电池直接充电必需加入平衡电路,所谓平衡电路就是分别检测单节电池的电压,把充满的电池屏蔽掉,未满的电池继续充,最后一节电池充电结束指示充电完成.
由上可得,平衡电路需要比较器低内阻MOS管等,且三串的高压锂电池充电器也价格昂贵,一般此方案多由单片机完成.
为了避免复杂昂贵的平衡电路和3串锂电池充电管理电路,而把串联的电池分开独立充电,这样就有了本电路板的方案,在不分开串联电池结构的情况下,利用3个独立电源把三组电源、地都分开.这样就可以完成充电且绝不会造成单个电池过充.
市场上出现的很多30 40 50元所谓3串平衡充,只要只有2个头输出接电池正负极,而不接电池抽头.都是不平衡的充电器,一般都是恒压12.6V电源充电器而已.
如果在电池端利用三串电池保护板,看似可以补充上述电源过傻的问题,但是保护板的保护电压都较高,单节4.3V左右.保护板都是在出现异常情况工作起作用才是合理的.依靠保护板做充电关断保护过于冒险.不符合设计原则.
1、为什么非要用3个电源?
其实我也不想啊,哈哈,电路的主要目的就是三路电源,地线,完全隔离,这样虽然电池是连通的,但是充电电位并不是相通的.如果有订做的3组副绕组的高频开关适配器,输出是三路分开,只有主绕组是共用的.这个是最佳的选择.如果你有这种适配器就爽了.这种适配器大多定做,很少有卖.
如果可以定做三路输出的充电器,这种方案的整体成本是最低的.唯一BUG就是芯片不会同时关断,如果要加入指示灯的逻辑电路,需要加入高低电位转换电路和逻辑电路,也有点费事了.简单的处理可以只用一个指示灯,只要这个灯转换,那基本可以判断为充满,毕竟电压差不会很大.
转自wxx4364238,特此感谢王工!
南京拓微深圳办事处
Mobile:13714937000 杨生
Tel:0755-25944176-802
E-mail:njtpyx@163.com
QQ:64595780
