输入12 V ,
输出12-72V ,任意调控
输出电流0.1A
请高手指点.谢谢.
用BOOST能否实现12-72V任意调压?
全部回复(17)
发你的波形过来.
这是10K电阻的负载
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/2635831252659334.jpg');}" onmousewheel="return imgzoom(this);">
这是10K并上1K电阻的负载.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/2635831252659380.jpg');}" onmousewheel="return imgzoom(this);">
整个实物如图所示
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/2635831252659446.jpg');}" onmousewheel="return imgzoom(this);">
所有波形都是电感处的电压波形.
![](http://u.dianyuan.com/bbs/u/81/2635831252659334.jpg?x-oss-process=image/format,webp)
这是10K并上1K电阻的负载.
![](http://u.dianyuan.com/bbs/u/81/2635831252659380.jpg?x-oss-process=image/format,webp)
整个实物如图所示
![](http://u.dianyuan.com/bbs/u/81/2635831252659446.jpg?x-oss-process=image/format,webp)
所有波形都是电感处的电压波形.
@soniclean
这是10K电阻的负载[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/81/2635831252659334.jpg');}"onmousewheel="returnimgzoom(this);">这是10K并上1K电阻的负载.[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/81/2635831252659380.jpg');}"onmousewheel="returnimgzoom(this);">整个实物如图所示[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/81/2635831252659446.jpg');}"onmousewheel="returnimgzoom(this);">所有波形都是电感处的电压波形.
用的STC的呀?
@soniclean
自己顶自己.刚刚做了个简单的实验.5V供电,PWM信号是50%的占空比.控制882三极管,电感是用磁环绕的,电感量为2.8mh,大一些就大一些,因为我的要求不高.主要是能够提供一个大致的电压并保证足够的电流就可以了.下面说下试验结果.负载10K电阻时,升压到16.73V.负载10K并1K电阻时升压到9.8V.续流二极管是1N4148.呵呵.说的有点乱啊.总结下,以后我可以根据负载的变化调节占空比进行稳压.可是我有一点想不明白.不是输出电压VO=VI*(1/(1-D))吗.
那个公式是工作在连续状态下的,断续时,跟负载就有关了
