求太阳能LED路灯升压驱动解决方案
额定输入电压:DC12V或24V
输出电流:350mA(带10个或12个1W LED)
太阳能LED路灯升压驱动解决方案
全部回复(13)
用2305可以输入DC12-24升压,效率大约85-88%左右,如需要实测具体应用参数,请联系我申请DEMO板.
其他LED驱动IC推荐
LED手电类,7135,7136,PAM2803等,高性价比的恒流驱动IC,
射灯类,SD42522,QX5241,
代理台湾ADDTEK品牌LED背光驱动IC类:AMC3202,A706,A723 等.
LED日光灯驱动IC方案:A704,和9910类完全不同的降压电路架构,比9910类性能更好,更多的IC推荐或索取资料,样片,技术支持
请联系QQ:310402694,电话:0755-82979245,13554836730卢生,深圳广鹏微科技
其他LED驱动IC推荐
射灯类,SD42522,QX5241,
@luxian
用2305可以输入DC12-24升压,效率大约85-88%左右,如需要实测具体应用参数,请联系我申请DEMO板.其他LED驱动IC推荐LED手电类,7135,7136,PAM2803等,高性价比的恒流驱动IC,射灯类,SD42522,QX5241,代理台湾ADDTEK品牌LED背光驱动IC类:AMC3202,A706,A723等.LED日光灯驱动IC方案:A704,和9910类完全不同的降压电路架构,比9910类性能更好,更多的IC推荐或索取资料,样片,技术支持请联系QQ:310402694,电话:0755-82979245,13554836730卢生,深圳广鹏微科技
高薪聘请高级电源工程师
详请请登录sangdabaili.com.cn
有意者请致电86330246 吴小姐
有意者请致电86330246 吴小姐
LM3423 应用LED升压驱动方案
国半LM3423芯片适用于高达75V的输入电压,可升降压应用,
可出高达20个1W串接 LED,应用太阳能路灯等,效率90以上;
VIN range from 4.5V to 75V
2% 1.25V Internal reference voltage
Current sense voltage adjustable from 50mV to 1.25V
High side current sensing
750mA peak MOSFET gate driver
Dimming MOSFET gate driver
Input under-voltage protection
Output over-voltage protection
LED ready flag
Low shutdown current, Iq < 1?A
Fast (50 KHz) PWM dimming input
Cycle-by-cycle current limit
Programmable running frequency
Fault timer pin
TSSOP-20 package
Applications
LED Drivers
Constant Current Buck-Boost Regulator
Constant Current Boost Regulator
Constant Current Flyback Regulator
Constant Current SEPIC Converter
Thermo-Electric Cooler (Peltier) Driver
TEL:(0)13760313075;
Email:ZHEB8110@163.COM;
MSN:ZHEB8110@hotmail.com;
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/81/1367671253445800.jpg');}" onmousewheel="return imgzoom(this);">
LED ready flag
Fault timer pin
TSSOP-20 package
Applications
LED Drivers
TEL:(0)13760313075;
![](http://u.dianyuan.com/bbs/u/81/1367671253445800.jpg?x-oss-process=image/format,webp)
XL6003是一颗突破传统电路拓扑结构,结合HVBCD工艺,大电流,高压DC/DC升压恒流LED驱动IC,
(1)它具有较宽的直流3.6V到36V输入电压范围(低压可以兼顾锂电供电)
(2)最高升压可到42V,可驱动串联12颗1W LED(同比其它品牌多驱动4~5颗LED)
(3)大电流1050mA持续电流输出,可驱动1W LED12串3并或3W LED12串
(4)EN脚可实现PWM调光,且自带软启动功能
(5)低至0.2V参考电压,可以有效提高系统效率
(6)输出42V过压保护功能
(7)内置过热保护功能
优势:宽电压输入,大电流输出,外围电路简单.XL6003应用简单,普通DC/DC升压拓扑结构,效率高达92%,适用于基于LED的汽车、路灯、 太阳能灯及LED背光驱动的应用.
(6)输出42V过压保护功能
(7)内置过热保护功能
美国国家半导体公司推出的SM1230系列电源优化器,可使太阳能的实用率提高到98.5%以上,SM1230的具体参数我会发到我的微薄上http://blog.sina.com.cn/icjun,我的Q1742108652
另外,我们国半的和飞兆的渠道,价格都非常好!
