给用Multisim的朋友一个惊喜、、
估计大家用Multisim仿真的时候都会发现没有TL494这个元件把、、
在网上搜了N久,终于在某个俄国的小网站上搜到了、、
多谢谷歌翻译、、
于是特此呈上这个东西、、
TL494NC.rar
顺便问下、、
TL494NC和CN有什么区别啊、、
全部回复(4)
jerry.li
谢谢!我下载了,怎么不能仿真?
怎么不能仿真?
jerry.li
@551718183
怎么不能仿真?
仿真时候总是出现错误
Multisim Convergence Assistant Summary Report
Outcome:
 The Convergence Assistant was unable to correct the problem.  Please consult the help documentation for more information about simulation errors and how to correct them.
Multisim Convergence Assistant Log
Step 1: Verifying Error Scenario
 ...completed.
Step 2: Setting parameter Integration Method (METHOD) to Gear
 Simulating...
   ...completed.  Simulation error still occurs.
Step 3: Setting parameter Initial Conditions to Set To Zero
 Simulating...
Step 4: Setting parameter MaximumTimestep (TMAX) to 1.0000e-004
 Simulating...
Step 5: Setting parameter MaximumTimestep (TMAX) to 1.0000e-003
 Simulating...
Step 6: Setting parameter Relative error tolerance (RELTOL) to 1.0000e-002
 Simulating...
Step 7: Setting parameter Shunt resistance from analog nodes to ground (RSHUNT) to 1000000000
 Simulating...
Step 8: Setting parameter Shunt resistance from analog nodes to ground (RSHUNT) to 100000000
 Simulating...
Step 9: Setting parameter Shunt resistance from analog nodes to ground (RSHUNT) to 10000000
 Simulating...
Step 10: Setting parameter DC iteration limit (ITL1) to 200
 Simulating...
Step 11: Setting parameter DC iteration limit (ITL1) to 300
 Simulating...
Step 12: Setting parameter Minimum conductance (GMIN) to 1.0000e-007
 Simulating...
Step 13: Setting parameter MaximumTimestep (TMAX) to 1.0000e-004
 Simulating...
Step 14: Setting parameter MaximumTimestep (TMAX) to 1.0000e-005
 Simulating...
Convergence Assistant completed unsuccessfully.
老版本的
