5 REN
帮忙看看 Max Ringer Load      5 REN(North Americal)
REN怎么译?
全部回复(9)
qaz33510
REN = Ringer equivalence number  振铃等效值
dannywang
@qaz33510
REN=Ringerequivalencenumber  振铃等效值
非常感谢,它是怎么计算的?相当于国内哪个指标?
qaz33510
@dannywang
一个REN的负载大约等於7K电阻串联8uF的电容(?),最好查一查EIA RS-470等有关资料.
dannywang
@qaz33510
一个REN的负载大约等於7K电阻串联8uF的电容(?),最好查一查EIARS-470等有关资料.
谢谢 谢谢!!!
dannywang
@qaz33510
老兄在吗,请问A resistor between this pin and ground sets the "break-before-make'time beween output transistion.这句怎么译?
qaz33510
@dannywang
老兄在吗,请问Aresistorbetweenthispinandgroundsetsthe"break-before-make'timebeweenoutputtransistion.这句怎么译?
直译是: 一支在这引脚与地之间的电阻设置了输出在转换间的先断后续时间.
dannywang
@qaz33510
直译是:一支在这引脚与地之间的电阻设置了输出在转换间的先断后续时间.
明白了,谢谢!
楚雄
这里有详尽的解释:
The ringer in the telephone presents a load that is an impedance made up
of a resistive part and a capacitive part. This impedance is called the Ringer
Equivalence Number or REN.
     In the US, 1 REN = 6930 ohms in series with 8uF. The
resistive part is from the coil in the ringer and the capacitive part is from
the blocking capacitor. If two 1 REN phones are both connected to the same line,
together they present a load of 2 REN which is 6930 ohms / 2 and 8uF * 2 or
2 REN = 3465 ohms + 16 uF.
     In Europe, 1 REN is defined differently as 1800 ohms +
1uF. As well, the ringing frequency is 25 Hz instead of 20 Hz. US Bellcore specs
call for the central office (CO) line card to be able to drive 5 REN (= 1386 ohms
+ 40uF) to at least 40 Vrms for ringing.
dannywang
@楚雄
这里有详尽的解释:Theringerinthetelephonepresentsaloadthatisanimpedancemadeupofaresistivepartandacapacitivepart.ThisimpedanceiscalledtheRingerEquivalenceNumberorREN.    IntheUS,1REN=6930ohmsinserieswith8uF.Theresistivepartisfromthecoilintheringerandthecapacitivepartisfromtheblockingcapacitor.Iftwo1RENphonesarebothconnectedtothesameline,togethertheypresentaloadof2RENwhichis6930ohms/2and8uF*2or2REN=3465ohms+16uF.    InEurope,1RENisdefineddifferentlyas1800ohms+1uF.Aswell,theringingfrequencyis25Hzinsteadof20Hz.USBellcorespecscallforthecentraloffice(CO)linecardtobeabletodrive5REN(=1386ohms+40uF)toatleast40Vrmsforringing.
谢了,老兄
