大家来谈谈高频机如何加自控电路!欢迎进来一起讨论
我有一台自制的SG3524  IRFP3424*8  双硅输出  一个频率调节  一个脉宽调节  应有3KW功率  现在唯一的问题是为什么有时下水会都都都的声音  如果用1KW太阳灯带机  则不见了  不过脉宽大了也有  搭载的瞬间会有很大的火花出现  我估计问题是在我的自控电路  请高手们帮帮忙  谢谢500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266496.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266506.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266512.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266520.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266540.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266546.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266551.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266557.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2874291258266571.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">图上管子只上了4个  现在是8个  上面的小板就是自控板   由继电器和晶体管 二极管  电容  电阻组成
全部回复(4)
tby2008
接1000W灯 没有声音 是主硅直通了 在前级没有保护时 很容易炸场管
脉宽过小或过大 直通就是这个并双硅电路的的缺点
主要是触发电路问题
如果脉宽调整过小  接大负载就关不断
脉宽调到10~30%在接大负载 就可以关断
建议硅触发用集成电路 不要用DB3
这个并双硅 还有一个致命缺陷 就是副硅
很容易软击穿 现象为 调整脉宽电位器
脉宽不变化
cxj2008
@tby2008
接1000W灯没有声音是主硅直通了在前级没有保护时很容易炸场管脉宽过小或过大直通就是这个并双硅电路的的缺点主要是触发电路问题如果脉宽调整过小  接大负载就关不断脉宽调到10~30%在接大负载就可以关断建议硅触发用集成电路不要用DB3这个并双硅还有一个致命缺陷就是副硅很容易软击穿现象为调整脉宽电位器脉宽不变化
首先谢谢你的热情帮助,我说的接1000W灯时没声音是都都都的声音没了,接灯试机则一切正常,但经实验发现,如果把脉宽调节电位器断开,也就是无穷大时.一样出现那种情况,只有都都声,听不到关断电感的工作答答答的声音.我也估计是没有触发成了直通,但是为什么又会一断一续的呢?还有下水时有了那种情况,如果把网抄往水面抬一点就能正常工作了.
tby2008
@cxj2008
不理解 你所说的嘟嘟声 是指什么发出的声音
网抄往水面抬一点 就相当于负载减轻了一些
你的关断电容是多少UF
在去掉副硅和二极管 输出接成单硅模式
输出接1000W灯 要能正常关断为好
我试过1UF轻松关断过
但一般常取6UF左右
cxj2008
@tby2008
不理解你所说的嘟嘟声是指什么发出的声音网抄往水面抬一点就相当于负载减轻了一些你的关断电容是多少UF在去掉副硅和二极管输出接成单硅模式输出接1000W灯要能正常关断为好我试过1UF轻松关断过但一般常取6UF左右
现在高频机用什么后级捕鱼效果好
