请教!这句是什么意思?
The former works in TM (Transition Mode, i.e. on the boundary between continuous and discontinuous inductor current mode), therefore at a frequency depending on both input voltage and output current. The latter works at a fixed frequency, imposed by the synchronisation signal, and is therefore
completely equivalent to a flyback converter
based on a standard PWM controller.
全部回复(16)
qaz33510
就是
前者工作于过渡模式 ......, 后者工作于固定频率 .......
wutao0808
@qaz33510
就是前者工作于过渡模式......,后者工作于固定频率.......
有一个更绕嘴:the control loop has a narrow bandwidth so as to be little sensitive to the twice mains frequency ripple appearing at the output.什么意思啊?
qaz33510
@wutao0808
有一个更绕嘴:thecontrolloophasanarrowbandwidthsoastobelittlesensitivetothetwicemainsfrequencyrippleappearingattheoutput.什么意思啊?
控制环有一个窄频宽使得它对出现在输出端的双倍工频的纹波不甚敏感.
wutao0808
@qaz33510
谢了,头大的翻译工作,脑子要进水了!
wutao0808
这是什么东东? open loop crossover
qaz33510
@wutao0808
这是什么东东?openloopcrossover
就这样? 还是open loop crossover frequency (开环交叉/交越频率)?
wutao0808
@qaz33510
就这样?还是openloopcrossoverfrequency(开环交叉/交越频率)?
是open loop crossover frequency,不好意思,呵呵,漏掉了
wutao0808
再请教:From energetic balance, it is possible to write:中energetic balance是什么东东?“有力平衡”?不对劲啊!
qaz33510
@wutao0808
再请教:Fromenergeticbalance,itispossibletowrite:中energeticbalance是什么东东?“有力平衡”?不对劲啊!
能量的平衡 ?
wutao0808
@qaz33510
能量的平衡?
有点意思,与能量有边,老外的脑子也象进水,有话就是不会好好说!
wutao0808
又来了!besides complicating things in getting a narrow overall bandwidth.中complicating things是什么东东啊
wutao0808
@wutao0808
又来了!besidescomplicatingthingsingettinganarrowoverallbandwidth.中complicatingthings是什么东东啊
because of the statistical spread of this parameter.中statistical spread是什么东东啊
qaz33510
@wutao0808
除了为得到一个窄的整体频宽而使事情复杂化之外…
...这参数的统计散布量
wutao0808
请教:a small filter capacitor is placed close to the VCOMP pin of the control IC to attenuate high frequency switching noise being picked up by the metal trace from the opto-coupler to the control IC. 中的metal trace是什么东东,明文是“金属制的轨迹”应该不是这个意思.
qaz33510
@wutao0808
请教:asmallfiltercapacitorisplacedclosetotheVCOMPpinofthecontrolICtoattenuatehighfrequencyswitchingnoisebeingpickedupbythemetaltracefromtheopto-couplertothecontrolIC.中的metaltrace是什么东东,明文是“金属制的轨迹”应该不是这个意思.
就是PCB 上的走线啊
wutao0808
@qaz33510
就是PCB上的走线啊
哦,哦,“大悟”谢谢!
