我在用10.5的PSPICE仿真时,不知电解电容的一个CMAX参数是做什么用的.而且放上去,仿真就不成功.
电路:500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/35/1133261165.gif');}" onmousewheel="return imgzoom(this);">
设置:500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/35/1133261192.gif');}" onmousewheel="return imgzoom(this);">
仿真:500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/35/1133261332.gif');}" onmousewheel="return imgzoom(this);">
ORCAD10.5版中电解电容的问题.
全部回复(27)
加了电解电容的电路:500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/35/1133262037.gif');}" onmousewheel="return imgzoom(this);">
仿真设置没变.但仿真结果却是:500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/35/1133262077.gif');}" onmousewheel="return imgzoom(this);">
@济公
加了电解电容的电路:[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/35/1133262037.gif');}"onmousewheel="returnimgzoom(this);">仿真设置没变.但仿真结果却是:[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/35/1133262077.gif');}"onmousewheel="returnimgzoom(this);">
请教高手们是什么地放错误?CMAX是什么?要怎样设置?
@天天6394
我用的电解电容都是ANALOG库中的C_elect模型,直接摆出来就没有什么CMAX参数,你试一试吧
请看我照你说的库中的元件:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133592391.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133592418.gif');}" onmousewheel="return imgzoom(this);">
你是不是10.5版的呢?
你是不是10.5版的呢?
@hongli88
你把电容换个方向或换成无极性电容试试
换了方向后,一样:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133592770.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133592784.gif');}" onmousewheel="return imgzoom(this);">
@hongli88
你把电容换个方向或换成无极性电容试试
换成无板性电容后:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133593098.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133593116.gif');}" onmousewheel="return imgzoom(this);">
是不是我下载的软件有问题呢?我就是在这个网上下载的.我再次试过,去掉电容就是又与上面一样正常了.
@济公
请看我照你说的库中的元件:[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133592391.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133592418.gif');}"onmousewheel="returnimgzoom(this);">你是不是10.5版的呢?
有哪位用10.5的大师傅能回我的贴呀?难道真的要我一定回到用9.2的去吗?如果有问题,还让这么多人来用10.5的干吗呢?
@济公
不好意思,我机器上有两个Orcad,上次在没关闭9.2的时候就把10.5打开了,才会被默认为9.2。10.5确实如你所示,有这个CMAX参数,我也是第一次看到,个人感觉是耐压,电解电容一般都有电压参数的。500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133754194.gif');}" onmousewheel="return imgzoom(this);">
你把电压具体值写上试一下吧,不知道行不行……
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133754271.gif');}" onmousewheel="return imgzoom(this);">
@天天6394
不好意思,我机器上有两个Orcad,上次在没关闭9.2的时候就把10.5打开了,才会被默认为9.2。10.5确实如你所示,有这个CMAX参数,我也是第一次看到,个人感觉是耐压,电解电容一般都有电压参数的。[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133754194.gif');}"onmousewheel="returnimgzoom(this);">你把电压具体值写上试一下吧,不知道行不行……[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133754271.gif');}"onmousewheel="returnimgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1133872512.gif');}" onmousewheel="return imgzoom(this);">
仿真图与上面的是一样的.
仿真图与上面的是一样的.
@济公
换成无板性电容后:[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133593098.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133593116.gif');}"onmousewheel="returnimgzoom(this);">是不是我下载的软件有问题呢?我就是在这个网上下载的.我再次试过,去掉电容就是又与上面一样正常了.
电容极性放反了
@济公
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133872512.gif');}"onmousewheel="returnimgzoom(this);">仿真图与上面的是一样的.
c7极性反了
