温升60K
请问安规内所写的温升60K ,是指在室温下升了60度?还是指温度升到60度?
请高人指点!!!   thanks
全部回复(9)
vicchc
应指在室温下上升了60度。
flytank
一般标准都是指25度环境下的温升,也就是60+25=85度
tfy8
是60度+你所测的环境温度.
wllvc
请弄清温升与温度是两个词语!
@wllvc
请弄清温升与温度是两个词语!
我记得我们测试时是这样的:取一杯水放置一天后的温度与被测温度之间的差就是温升!
bluesea
@wllvc
请弄清温升与温度是两个词语!
温度?是绝对值。
温升,是相对值,可以理解为温度的增量。
数值上 温升=测量点温度-环境温度。
wllvc
@yalanjiang
瞎扯,毫无科学道理!
wllvc
@wllvc
瞎扯,毫无科学道理!
正确的室温测试方法:
The ambient temperature is to be measured by means of a thermocouple immersed in a bath of 15 milliliters of mineral oil in a glass container. The oil bath is to be placed:
a) At the same level as the horizontal plane formed by a line that passes through the portable luminaire halfway down its vertical length; and
b) At least three unit diameters from the product horizontally.
----------摘自UL153-12th Edition
loglio
@vicchc
应指在室温下上升了60度。
同意
