产品/供求资讯
急需C=O抽样方案,谢!!!
急需C=O抽样方案,谢!!!
急需C=O抽样方案,谢!!!
全部回复(5)
longqian
老兄你需用那一种的啊!说的不太明白啊!
lulimin
兄弟,抽样标准还是GB2828呀,只是判断要求变成了:0收1退。
cust9421
@lulimin
it is Another series of sampling plan named "Zero Acceptance Number (C=0) Sampling Plans". it sames as MIL-STD-105 or GB2828...
I'm searching it.
cust9421
1136355112.pdf
Enclosed please find the standard(MIL-STD-1916),Perhaps it can be help you to solve the problem.
jeremyho88
@cust9421
1136355112.pdfEnclosedpleasefindthestandard(MIL-STD-1916),Perhapsitcanbehelpyoutosolvetheproblem.
就是这个,已经代替了MIL-STD-105E,请参考
1136379665.doc
【 DigiKey DIY原创大赛】无频闪台灯改装
hellbaron
【 DigiKey DIY原创大赛】-基于STM32G030CBT6的GPS北斗双模授时终端
小小申
【 DigiKey DIY原创大赛】基于STM32的直流生理电刺激治疗仪
大_树
【 DigiKey DIY原创大赛】+ 电压电流在线监控器
wenaochina
AD工程PCB文件导入LCEDA故障问题解决。
程序小白
